Fantasy Air Allegro Electric ARTF airframe
Edgeflyer
This is a nice quite large model of an ultralight produced from 2000 to 2008. Plenty of info online. I acquired it new and unstarted but without manufacturers details  some time ago but then after a slow start other things intervened.
It's an interesting one for relaxed flights with something a bit different about it.
It's 70 inch span all balsa and nice covering scheme. Undercarriage with good quality spats, wing braces and 2 part wings with aluminium tube joiner. I decided to epoxy on the T tail as the original single screw demountable was slightly tilted and a bit flexible. I installed a Hitec HS82MG under the t tail to control the elevator. It is included as it has its wiring back to the Rx area .
No other servos or electrics are included. It's very light and will only need a brushless motor around a 40 glow equivalent at most on 3s lipo and I would guess a 40 amp esc and ideally 3 bladed prop.
Cheap price at £90 as I don't have enough time and commitment for this project.
Photos of the kit on request but the image is it's big brother.
