Hinge gap
Learner
Hi all, recently bought a plane from Hk (Dancing wings extra) as a sale item.Looks nicely made and coverings spot on.
Instructions say to fit ailerons but their already fitted,  the gap is much bigger than I would have done (2 to 3 mm)  its a 5/6 cell 1500mm aerobatic/3d plane so could this be a concern (flutter).
Don't really want to cut and redo unnecessarily, but should I?
Edited by Learner
Hi Learner,
In a world, of perfect aeronautics, there would be no gap at all, so the less the better.  Chemists sell a wonder tape called Blenderm. It sticks like you know what, and is a wee bit flexible
You could use this to seal the gap, and your perfect rolls would be the envy of all
ernie
4 minutes ago, Ernie said:
Hi Learner,
ernie
I did think about tape but not sure if I could do a neat job!
5 minutes ago, Philip Lewis 3 said:
Does the trailing edge of the aileron line up with the trailing eddge of the wing? If it doesn't (sticks out too much which, in theory it should) then I would cut and rehinge with CA hinges to make perfect.
Trailing edge is spot on.
