VMC Balsa Basics Spitfire
4 hours ago, Daren Cogdon said:
Trial assembly. No more building - covering next!!
Also, the tightest servo fit I have ever seen. Had to take the stickers off them so they would go in the holes!
You could have filed/sanded the wood slightly to open up the hole.
They're all good.
I'd forgotten that I had the extras pack that was released when the kit first came out (radiators and later-model exhaust stubs), so made these up this morning.
Once I decide on a colour scheme, I can figure out which parts I want to use!
The postman arrived this morning with a box about 4ft long on his shoulder.  I knew what it was.
When I saw this on eBay, I felt that I just had to get it.  It needs a little work, but the airframe itself is sound and all the electrics work.
  • Like 3
It doesn't look like I've done much to it, but there has been some progress!
New exhaust pipes - these came from the kit that I have, and they definitely give the model a bit more character.  I replaced the rudder pushrod, as the one that was fitted before wasn't great and had a bit too much flex in it.  The motor was also spinning the wrong way, but this wasn't helped by the fact that I couldn't get the bolts out of the firewall to pull the motor so that I could change the wires around!  I've ended up having to do minor surgery under the nose so I could get into the wires and swap them over - there's a scar, but it's minimal (thankfully!).
A couple of little things still to do, and that should hopefully be it!
  • Like 3
Had a successful first flight with the Spitfire today!
She flew really nicely - rather floaty, but easy enough to fly.  She was a little tail-heavy, but I put that down to me using the lighter 1800mAh battery instead of the 2200.  The landing was a bit bumpy, as she didn't want to come down, either!
But yeah, a definite success.
Annoyingly, the video is silent, but here's the proof....!
  • Like 5
  • 3 weeks later...
