Storm Petrel 150%
DG1000M
The fuselage now has a set of main U/C wheels, difference here is I have made the U/C a little stronger due to the expected weight, which I think will come out at around 11lbs.
Where the 8 SWG wire is joined I have used 0.3mm wire and then used lead solder to make stronger and then a little light sanding around the joint areas.
