Help with model identification, please
Can anyone help with identifying the model shown below?
The fuselage formers have printed part numbers on them, so presumably the model has been built from a kit. The wingspan is 48 inches, uses three channel (engine, rudder and elevator) and is powered by an Enya .15. I acquired it from the estate of a former club member but have no other details.
Many thanks
Upload 1.heic
Upload 2.heic
Hi Leccyflyer and Robin. Thanks very much for the responses.
There are no struts on the model as built, but the undercarriage looks spot on and otherwise it looks a very good match to the Graupner plan. I'm thinking about converting it to electric so the fuselage plan will be very useful. Might even add the struts as a late addition!
The Graupner plan is well populated with part numbers, so you might be able to match some of those up for a definitive answer. Even if it turns out not to be the Graupner electrifying the Cub ought not present too many difficulties and you can now search for any examples which have been converted to electric.
