Small head and shoulder pilot figure.
Erfolg
I am trying to find a file that prints out an approximate 1/16 scale pilot figure. It would be best if it could be loaded into Autodesk Fusion, for further rescaling.
It will be for a TN A10 Thunderbolt (which seems to be about 1/16 scale).
Can anybody help?
Can anybody help?
Re size in your slicer software rather than Fusion.
This is a jet pilot file that I've printed and used several times, in different scales.
It's provided for download a 1/12th scale, but it's simple to rescale it in Cura, using the scale button - either as a simple % change, or by scaling to a critical dimension that you are aiming for.
https://www.thingiverse.com/thing:1105001
Image from Creality's version of the Cura slicer, which is very similar, showing the pilot figure scaled to 70mm across the shoulders. That's somewhere between 1/7th and 1/8th scale.
I don't currently use Cura, I use Creality's reworked version of it, but when I did used to use  Cura the rescale function was in the same place as in Creality Slicer - second icon down after the Move function, and signified by what look like two castles, or power station cooling towers. I can have a look on my old laptop next time I'm out in the workshop and check, but that is my memory of where it was.
Thanks to all for the help and guidance.
I have successfully printed  out both versions of "Jet Pilot". One version printing easily, the alternative a little problematic.
I have also used Cura to rescale, again successfully. I have learnt something again.
Some formal training of using both Fusion and Cura would increase my abilities. At my age, the opportunities are very limited, reliant on videos an definitely this site.
Thanks again
