Bernd Lewerenz Posted November 9, 2024 Share Posted November 9, 2024 Every now and then I also have to tidy up my hobby room. So I noticed how much pieces of balsa and plywood were lying around uselessly.Too little for a large model, but also too much to simply dispose of.Last winter, a colleague had brought a small high-wing monoplane and flew with it.It should be possible to realize something like this with the leftover material.While looking through my plans, I also found a suitable object, namely the Aviatik biplane by Jaromir Pipek.With a span of just under a meter, it would fit in my car when assembled, In my plan, a nitro engine with 2.5cm3 is still planned, but for me only an electric drive was an option. As the warm season was now over and so it was time to get started. 2 Quote Link to comment Share on other sites More sharing options...
Bernd Lewerenz Posted November 9, 2024 Author Share Posted November 9, 2024 The tail unit. The rudder and elevator are made of 6 mm balsa strips and are shaped like a Focker from the First World War. It is quickly assembled on the foil-covered plan, using only wood glue. 1 Quote Link to comment Share on other sites More sharing options...
Bernd Lewerenz Posted November 9, 2024 Author Share Posted November 9, 2024 The fuselage It is a simple construction consisting of two side parts, reinforced with 0.8 mm plywood in the front third.Lightweight 2mm plywood former are also used there, while 4X4mm balsa strips determine the shape in the rear section.In other words, really classic model making, which I always enjoy with a good cup of coffee.I know, you prefer tea.Once the basic construction was complete, the conversion to electric drive had to be considered.The motor mount for the burner was omitted; instead, the mounting cross for the electric motor was attached to the front former. 4 Quote Link to comment Share on other sites More sharing options...
martin collins 1 Posted November 9, 2024 Share Posted November 9, 2024 Watching your build with interest 😃 Quote Link to comment Share on other sites More sharing options...
Bernd Lewerenz Posted November 10, 2024 Author Share Posted November 10, 2024 Adjustment of the wing canopy with + 2 degree angle of attack 1 Quote Link to comment Share on other sites More sharing options...
Bernd Lewerenz Posted November 26, 2024 Author Share Posted November 26, 2024 (edited) THe wings. Bad weather in Germany and a good reason, to build the wing Upper and lower wings are both drawn in the plan and the only difference is the wingspan.The bracket for the undercarriage and the wing bracket are also positioned in the lower surface.First, 50 ribs had to be made from two, four and five millimeter balsa wood.😂 Since all ribs are the same size, a master rib made of 5mm plywood was sufficient.Admittedly a somewhat monotonous job, but better than housework.Once the wing connectors had been made, the construction of the lower wing could begin. Due to the flat underside of the ribs, the four halves were quite easy to assemble.Both wings have neither spar webbing nor nose planking.The reason is probably the main spar, which is very thick at 12X5mm.Images later Edited November 27, 2024 by Martin Harris - Moderator Bernt - you might not realise that the first word in your reply is regarded as bad language so I’ve replaced it with “Bad”. Quote Link to comment Share on other sites More sharing options...
Bernd Lewerenz Posted November 27, 2024 Author Share Posted November 27, 2024 Both wings are almost finished and are already taking their place; they are not yet attached and are therefore slightly crooked 2 Quote Link to comment Share on other sites More sharing options...
Bernd Lewerenz Posted November 28, 2024 Author Share Posted November 28, 2024 Sorry will avoid bad language in futur😇 Quote Link to comment Share on other sites More sharing options...
Bernd Lewerenz Posted November 28, 2024 Author Share Posted November 28, 2024 Adjusting the angle of attack of the upper wing of plus 2 degrees 3 Quote Link to comment Share on other sites More sharing options...
Jonathan M Posted November 28, 2024 Share Posted November 28, 2024 1 hour ago, Bernd Lewerenz said: Adjusting the angle of attack of the upper wing of plus 2 degrees The correct term is angle of incidence, i.e. angle of wing to fuselage datum line. Angle of attack would be the attitude of the whole aeroplane, i.e. fuselage datum, to its flight path. If the incidence angle of the upper wing is 2°, what will be the lower wing's angle? Nice winter project by the way! 👍 What will be your electric power-train? Quote Link to comment Share on other sites More sharing options...
Bernd Lewerenz Posted November 29, 2024 Author Share Posted November 29, 2024 16 hours ago, Bernd Lewerenz said: Adjusting the angle of attack of the upper wing of plus 2 degrees 21 hours ago, Bernd Lewerenz said: Sorry will avoid bad language in futur😇 Quote Link to comment Share on other sites More sharing options...
Bernd Lewerenz Posted November 29, 2024 Author Share Posted November 29, 2024 Hello and thanks for the tip. The angle of incidence of the lower surface is zero degrees.The tail unit also has zero degrees, so you can say that the angle of attack is plus 2 degrees altogether.The motor is an Extron 2712/26 KV100 Controller 30Ampere Servos: 2X Master S766MG/MG= metal gears 1 Quote Link to comment Share on other sites More sharing options...
Bernd Lewerenz Posted December 1, 2024 Author Share Posted December 1, 2024 The undercarriage is being bent.It looks a bit weird, but that's the perspective.The undercarriage consists of a front and rear bracket with 2 mm steel wire.Then comes the 3 mm axle for the wheels. Then everything is soldered Quote Link to comment Share on other sites More sharing options...
Bernd Lewerenz Posted December 2, 2024 Author Share Posted December 2, 2024 The undercarriage is ready for installation 1 Quote Link to comment Share on other sites More sharing options...
Bernd Lewerenz Posted December 2, 2024 Author Share Posted December 2, 2024 Ready for covering 4 Quote Link to comment Share on other sites More sharing options...
Murat Kece 1 Posted December 2, 2024 Share Posted December 2, 2024 looking very nice 👍 Quote Link to comment Share on other sites More sharing options...
Bernd Lewerenz Posted December 2, 2024 Author Share Posted December 2, 2024 Thank you, made from scrap wood Quote Link to comment Share on other sites More sharing options...
Bernd Lewerenz Posted December 16, 2024 Author Share Posted December 16, 2024 Final work. Again, classic model building. The fuselage was treated with pore filler and covered with paper, while the wing and tail were covered with Proficolour2 from Practical scale. This film is ideal for vintage models.Two table tennis balls painted by my wife serve as pilot heads and look funny. They are also very light.The plan shows the emblems of the German Air Force and a machine gun..However, I have opted for a peaceful airplane.That's why I have attached flying doves to the fuselage and wings. I think that's better in view of the world situation. Now I have been waiting for better weather for the first start. 4 Quote Link to comment Share on other sites More sharing options...
Bernd Lewerenz Posted January 6 Author Share Posted January 6 Hello together,wich you a happy new year and allways happy landings. My first landing with the Aviator on the first day of the new year was a disaster.The take-off was good, but in the air the model was not controllable.It staggered through the air and could only be forced into a turn with maximum rudder deflection.After about 30 seconds of flight the model crashed. Frustrated, I drove home.Due to the low mass of the model, the damage was not serious and was quickly repaired.Now my ambition was awakened and I wanted to find the reason for the crash.The electronics were not the reason.Research on the Internet revealed that the upper wing of a biplane must always be set at a negative angle. The lower wing, on the other hand, must be set at a positive angle.With my model it was the other way around.You always learn something new, even at an advanced age.Now I have changed the angle of attack of both wings and increased the side thrus.Upper Wing Minus one degree, lower wing Plus 1Degree.I admit I'm a bit scared of the next flight, but as soon as a nice calm day arrives, I'll start the Aviator and report back.Keep your fingers crossed. 1 Quote Link to comment Share on other sites More sharing options...
Jonathan M Posted January 6 Share Posted January 6 (edited) Sorry to hear this was your experience. But I'm not sure your diagnosis of the problem or the solution is correct. One has to assume that the designer knew what he was doing and that numerous other examples of this model have flown perfectly well with the top wing at 2° and the lower one at 0° as specified. (I've made several small free flight biplanes powered by rubber, electric, CO2 and diesel, which have all had the upper wing set at a slightly higher angle than the lower one - and they've all been stable and gently self-correcting if disturbed by a gust or similar.) It's difficult to discern from your description why the model flew briefly as it did, but there could have been other complicating factors: did you build in any or enough down-thrust? how accurately did you measure and build the upper wing angle - perhaps there was some extra error that crept in? was the weight of the model within specification, and - importantly - was the centre of gravity in the right place (not too far forward or back)? was the powertrain (motor, lipo, prop) correctly specified? were the control throws adequate? etc As indicated above, I come from a free flight background. Here if one small change is made in trimming a model (say power, prop, side- or down-thrust, nose- or tail-weight, wing warp, rudder deflection, etc) then everything else is effected. The process of trimming is therefore a careful one of changing only one factor at a time then carefully observing the flight behaviour before increasing or decreasing that change if necessary, then making a small change to any of the other factors that could be effected. Edited January 6 by Jonathan M Quote Link to comment Share on other sites More sharing options...
Bernd Lewerenz Posted January 7 Author Share Posted January 7 Thank you very much for your support. The down thrust is 4Degree( my Kapitän had 3degree and this was to litle) To measure the angle of attack I use the setting angle gauge from Robart and an additional electronic one with digital display, both displays were about the same The weight is about 800g ready to fly. The engine is from my Kapitän and both models are similar Airscrew is 9X6 I understand your arguments very well, because Jaromir Pipek is a well-known model maker in Germany.On the other hand, my new information about the angles comes from Ralph Müller, who has also developed many models and was very shocked by Plus 2Grad. So the only thing left is learning by doing. If the weather is good, I'll try a new start and report on it. let's be honest, if everything always works well, it gets boring too. 1 Quote Link to comment Share on other sites More sharing options...
Jonathan M Posted January 7 Share Posted January 7 Interesting, thanks for the extra detail. Good luck with the next test flights. Quote Link to comment Share on other sites More sharing options...
Bernd Lewerenz Posted January 27 Author Share Posted January 27 Last week I flew my Aviatik with the newly adjusted angle of attack.And this time it worked: the aircraft flew without any problems and was stable.After a few rounds, I wanted to land.During the landing approach I was blinded by the very low sun.As a result, I flew too low towards a small wood and the model landed on a tree at an altitude of about 1 meter.At almost 76 years old, I no longer climb trees.So there was nothing left to do but cut down the tree. It was dead anyway.The fuselage was destroyed, but the wings remained intact.That's why I have now mounted the wings on my Kapitän and corrected the angle of attack there too.Now my captain is also flying stably and I at least have something from my aviation.We model pilots are all familiar with this.Sometimes you have bad luck.But never mind, my next model is already in the works. It's a Klemm25 from Krick. Quote Link to comment Share on other sites More sharing options...
Bernd Lewerenz Posted January 27 Author Share Posted January 27 Sorry, I mean 10m of course Quote Link to comment Share on other sites More sharing options...
