John Wagg Posted November 10 Share Posted November 10 A new motor / ESC set up and when closing the throttle at zero the motor does a dead stop. This is without the prop on.! It's as if a brake is momentarily applied then releases. I have had this before on another plane but I don't know how I stopped it from doing it. Any suggestions gratefully appreciated. Thanks. Quote Link to comment Share on other sites More sharing options...
Frank Skilbeck Posted November 10 Share Posted November 10 The ESC might be programmed to do this, you need to set brake off in the ESC programming. The brake function is very useful with folding props (i.e. gliders) without it the prop will carry on windmilling and you get extra drag. Quote Link to comment Share on other sites More sharing options...
John Wagg Posted November 10 Author Share Posted November 10 Thank you. I have found the instructions so will have a play tomorrow, Cheers. Quote Link to comment Share on other sites More sharing options...
John Wagg Posted November 11 Author Share Posted November 11 Managed to alter the program to remove the motor brake. Took a bit to comprehend the instructions and, with a little bit of guidance from this video, job done. Thanks. 1 Quote Link to comment Share on other sites More sharing options...
