Futaba TX T6K Replacing an existing RX with a new/different RX
You can bind as many rxs to one tx model memory as you like.
Just select the required model memory and bind.
No need to delink the other rx. That is why there is nothing in the instructions about doing it!
If you really want to break the link just bind it to a spare model memory.
You would naturally rebind if you reuse the original rx in another model as part of the set up process anyway.
  • Thanks 1
Futaba doesn't have a model match facility, The tx only has one bind to each rx, and even deleting the model memory - unless it was set either as T-FHSS or S-FHSS, similar to FASST/FASSEST, then it will work.
