Steve Bell 3
Posts posted by Steve Bell 3
Hi Can anyone help me out with programming a Pelican Ray esc. I need to know how to set brake to on.
Cheers Steve
Steve
Go to eBay and type in search bar matt silver model covering film .
With any luck you should find something that suits.
steve
Looking at buying a fx22 transmitter. Which I believe shares it's software with the 14SG . Does anybody know if software version is pre the new eu legislation. The tx has version 3.1 installed.
Thanks in advance for any assistance
Regards Steve
Thanks for the replies, Percy Ivan's plans ? Have you a link for them.
Regards Steve
Looking for recommendations for Mosquito plan .needs to be for electric motors and around 40 inch in span. Cheers Steve
Hi Guys
It's been a while since my last post I 'be finished my Vulcan and had it's maiden flight all went ok. I used a Bungee to launch it.Finished weight ready to fly complete with flight battery is 4lb 1oz I've built it without retracts as our flying site isn't suitable for them. The main mod that I had to make was to position the battery between formers f3 and f5 to achieve the c of g as per plan.
Steve
Bad luck Glen I'm still plodding on building my twin pusher version it is way tail heavy. It will definitely need the battery in the nose If I'd known before sheeting the fuselage I could have built in a battery box now I'll need to cut into the front and then rebuild it. I also think it may be wise to build in a hard point for a hook to bungee launch it as air speed seems to be a launching problem , well back to the grind .
Well done John
I was beginning to think this was going to be another white elephant . I'll be dry fitting everything to check where the battery needs to be located in order to balance the model before I cover it . I don't think you've built a tail heavy model as when you look at the plan most of the weighty bits are behind the c of g.
Thanks for the replies guys I've got some from Puffin models virtually the same spec.
If like me your building the pusher version beware the recommended motors have been discontinued. Darn it
Advent Prize Draw - 1st Dec (now closed)
in All Things Model Flying
Add me
