Chris Channon
Posts posted by Chris Channon
Flair Cub, perfect match.
Regards
Chris.C. -
Sorry meant to add, petrol evaporates really quickly so it just leaves a trace of oil that wipes off the gloss varnish.
Regards
Chris.C. -
I use Polyurethane varnish, not the fast drying one the spirit based varnish.
Regards
Chris.C. -
Yep good mag, I wish someone would sort out the spelling on the advert for the on-board glow, last time it was "good buy to dead sticks" now it's "good by to deadsticks " grrrrr
Have a good day
Chris.C -
Stick on lead wheel weights from ebay, very cheap brill.
Chris.C. -
Brilliant JM, thank you.
Chris.C. -
Hi all, wondered if you can help. I have been given a quad copter and it is fitted with AX2810Q KV750 motors. What size props should i buy for the quad ( it is quite a large carbon fibre machine )
Thank you
Chris.C. -
Hi John just had a thought ( does not happen often) you can buy ether from ebay, all you need is parrafin and castor oil to blend your own in equal parts. We used to do this years ago when chemists were happy supplying ether in brown glass bottles.
Regards
Chris.C. -
Hi John, i used to get mine from Chris at Portsmouth models but he closed up shop about 6 months ish ago.
Model Technics will deliver by courier but a minimum of 4 gallons so really expensive. I will ask someone who is going to the Nats to get me some, have you tried Sussex Models ?
Not much help sorry but i will have a think.
Regards Chris -
Have to say, i would be the first in the queue, brilliant idea.
Have a good day
Chris. C. -
I always thought the engine leaned out a bit as it unwinds in the air, not richer.
You learn something new every day !
Have a good day
Chris.C. -
Flair Cub foam wing version with a Saito .40 up front, perfect combination.
Chris. C. -
Hi all, why are petrol 2 strokes so much noisier than a glo engine ? Is it just because the petrol engine silencer is not as good as a glo engine ?
Thanks all,
Chris.C. -
Hi John, just bought one to go in a Wots Wot, not run it yet but seems ok, i will report back in a day or so after it has run / flown.
Chris. C -
I am just wondering if the 1st lo-boy i built I didn't bother with the flap and on the last one I built as 5 ch.
Age thing !!
Chris.C. -
Cheers Richard, i am not often right !!😁
Regards
Chris.C -
Hi Alan, yes you are correct, i forgot the re-vamp was "Lo-Boy 5 with flap" Then the turbo came out, i have to admit i thought they were brilliant for the time, teally nice easy build, i will have to look out for another.
Regards
Chris.C. ( stand corrected dept ) -
Hi all, I think when the Lo-Boy had its make over and fitted the central flap it became the Lo-Boy Turbo ....
Regards
Chris.C -
Thank you very much all, I just wanted to make sure i will be adhering to the rules.
Thanks again
Chris.C. -
Good afternoon all, just a quickie, can anyone fly a turbine model ? ie no A B or C cert just a competant flyer ?
Thanks all
Chris C. -
Strange, just checked mine ( futaba, hitec, sanwa) and they all dis-connect the charger from the batery when switching on.
Very strange.
Chris C -
Worthless,!!! Give them to me and I will dispose of them (keep ) them for you..!😁
Hi all, just a quickie. The fuel in a four stroke model engine, is it pulled in by the down going piston or pushed in by atmospheric pressure ?
Thank you
Chris C
What Sports Aerobatic for an ASP 70 Four Stroke?
in All Things Model Flying
