Radio problems
Barrie Cook
Hi Guys, anyone know of a simpler way to programme the 3810 than the handbook. As a 77 yr. old who is coming to terms with his toaster I am having a problem, Might even prop the garage door open with it and go back to non computerised equ. that I have been using for the last 40 years. HELP someone please. (Still got some Harry Brooks servos in the junk box.!!!!!)
Barrie,
         Go to the `List' function in the menu, select what you want to change and just play with the thing with a servo  plugged into what ever channel you a playing with. You can then see the result of the playing, and you will quickly get the idea.  Mind you the 3810 is a pretty comprehensive piece of kit and can be a bit boggling to begin with. You can't break anything so have no fear. Read the specifics of the function in the manual and just have a go.
Evan.
