Gaz Elliott Posted November 30, 2011 Share Posted November 30, 2011 Got an old minium with more glue holding it together and weighs too much. Taxis round well! Going to rip out and have made templates for Depron shockie but how thick or thin should I use? Just hoping to do a profile Cessna Quote Link to comment Share on other sites More sharing options...
Cyclicscooby Posted December 1, 2011 Share Posted December 1, 2011 I would have thought 3mm with a CF stiffner would be ok, perhaps with a doubled plate on the nose n belly Have you got the worm drives, or the magnet servo's with a proper arm..?? I only ask as I had a worm drive just cease up for no reason, and the 4ch with magnet servo's, started flipping the servo's 180 degs over when I fitting it into a Guillows Cub.. Luv Chrisie.. xx Quote Link to comment Share on other sites More sharing options...
Gaz Elliott Posted December 1, 2011 Author Share Posted December 1, 2011 It is a 3 channel Cessna with worm drives. All the parts have been removed including control horns ready to go. The arms are good and worms work..... Or have I spoke too soon.? The used to float around the hall for a relaxing flight . Thought it might just help out a friend .. But not when it was. Just running round the floor due to glue over load!!!!!! Quote Link to comment Share on other sites More sharing options...
kevin wild Posted December 12, 2011 Share Posted December 12, 2011 Hi I ripped the innards out of a park zone p51 and made my self a shockie type indoor plane it's 2mm depron apart from the nose where I've glue 6mm either side to take the knocks. the wing has a 2mm carbon spar and a kf section. I fly in a single basket ball size hall and it's plenty slow enough. if i remember correctly it's 35g with the battery I've also built a Cessna from the same system. 2mm built up fuselage and 3mm wing. the wing doesn't have a carbon spar. i did stick a single piece of sellotape on the underside though. It does bow a little on sharp turns but never let me down. the undercamber probably gives it a bit of stiffness too have fun and if first you don't succeed then get the knife out and hack it a bit works for me kev Edited By kevin wild on 12/12/2011 11:54:46 Edited By kevin wild on 12/12/2011 11:56:17 Quote Link to comment Share on other sites More sharing options...
Gaz Elliott Posted December 14, 2011 Author Share Posted December 14, 2011 Dooh I have cut out a profile frame and glued together but in my haste have found I've lost a small cog that fits in the worm drive. It's the one on the motor. The smaller of the two . I have swept the floor and scoured the debris , shook the mat all to no avail. Anyone know where I can source one from??? Quote Link to comment Share on other sites More sharing options...
