Del Wheatley Posted May 29, 2012 Share Posted May 29, 2012 Evening all I'm looking to buy a couple of 4 stroke engines and the price of these compared to os engines looks good but whats the quality of them like?Are they reliable?and do they last well? Cheers Del Quote Link to comment Share on other sites More sharing options...
Reno Racer Posted May 29, 2012 Share Posted May 29, 2012 Del, Currently run 3 of these a 61 and 2 91s. Never had an issue. Very relieable and once broken in and set with a tacho, i never have to fiddle. Not as much power as an OS, but since most buy 4 stroke for scale jobs, that shouldn't be an issue. For the price these engines are real winners. Bonus is that mufflers and accessories for OS fit them. 61 is in a Pulse XT40. 91 is in my Corsair (ICON/AVTAR image) and one fitted in my 91 size Decathlon. 61 swings a good 12x6 MA K series prop. the 91 runs best on a 14x6, again I use MA K series prop. Chris Quote Link to comment Share on other sites More sharing options...
Djay Posted May 30, 2012 Share Posted May 30, 2012 Unless you require every ounze of power from the engine, these are my first choice, for price, performance and reliability. Run mine in over 50c temps, humid and dusty, with no after run oil, and all mine are still going strong after many years. I have from 52 fs to 1.80 fs. Highly recommended. Spares are also cheap and easily available. Darryl Quote Link to comment Share on other sites More sharing options...
Lee Smalley Posted May 30, 2012 Share Posted May 30, 2012 Yeah good solid engines, no where near as powerful or as good as os but very good anyway, Quote Link to comment Share on other sites More sharing options...
Del Wheatley Posted May 30, 2012 Author Share Posted May 30, 2012 Thanks guys,ones going in a Nijhuis 62" spit, probably a 70 so it'll swing a sensible size looking prop and the others going in the basic 3d kit i won but that plan says it needs up to a 53 2 stroke so i'm not sure what size to get for it. Quote Link to comment Share on other sites More sharing options...
Steve Hargreaves - Moderator Posted May 31, 2012 Share Posted May 31, 2012 Another vote for ASP from me too....not as good as OS but not as different as the price gap suggests.... If I remember correctly didn't Tony use an ASP61 in his Spit? The 61 4 stroke is effectively a "big bore" 52 & shares the same crankcase....the 70 is a good bit bigger.... ASP do a 52 2 stroke which would be good in your Basic 3D. You would be looking at the 70 at least as an equivalent 4 stroke...IMHO... Quote Link to comment Share on other sites More sharing options...
Del Wheatley Posted May 31, 2012 Author Share Posted May 31, 2012 mmmmm the 70's a good bit bigger,that might change the plan slightly.Unless the 61 will swing a 3 bladed 12"/13" prop.The spit hasn't got to be a rocket ship so the next question is will an asp .61 be ok with the above mentioned prop size. Sorry still learning what works with what. Quote Link to comment Share on other sites More sharing options...
Steve Hargreaves - Moderator Posted May 31, 2012 Share Posted May 31, 2012 Like Christian I have a 12x6 on my 61 in a Pitts Spesh & it pulls very nicely...I think it might struggle on a 3 blader though....especially a 13" jobbie.... Quote Link to comment Share on other sites More sharing options...
Del Wheatley Posted May 31, 2012 Author Share Posted May 31, 2012 Cheers steve,it might be worth my while finding out how much bigger the 70 would be and if theres enough room to fit it in the cowl. Quote Link to comment Share on other sites More sharing options...
Former Member Posted May 31, 2012 Share Posted May 31, 2012 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Del Wheatley Posted June 1, 2012 Author Share Posted June 1, 2012 Posted by Tom Sharp 2 on 31/05/2012 21:49:55: ASP have a different metal technology than OS. You need to run a gallon or more fuel through them before they give full power. OS give full power from day one. After doing some research on sizes etc it turn out the asp's are quite big and heavy compared to OS.An os fsa 72 is shorter than the asp 61 and a lot lighter.looking at os's web site will swing the right prop happily.so the decision is made,it'll be dearer but worth it in the long run. Quote Link to comment Share on other sites More sharing options...
