Modonaut Posted July 10, 2013 Author Share Posted July 10, 2013 Both wings constructed now with just servo mounts to finish. The total all up weight so far is 2 lbs- that includes fuselage, all wings, tailplane, fin and wheels. Probably finished weight I would guess will be between 3 and 3 1/2 lbs. Quote Link to comment Share on other sites More sharing options...
Mike Etheridge 1 Posted July 10, 2013 Share Posted July 10, 2013 I have heard before on a Super 60 blog that ailerons do not work particularly well on the Super 60. I had intended to make up my wings possibly with ailerons but increase the dihedral from that recommended and just use the ailerons for trimming. Alternatively I thought of mixing in rudder movement with the ailerons with the wing set to the recommended dihedral? My Super 60 repairs were almost completed last weekend with just the front canopy replacement outstanding but partially finished. Engine is re-fitted on a new ply mount and just needs a new propeller. MJE Edited By Mike Etheridge 1 on 10/07/2013 23:43:22 Quote Link to comment Share on other sites More sharing options...
Modonaut Posted July 11, 2013 Author Share Posted July 11, 2013 Posted by Mike Etheridge 1 on 10/07/2013 23:39:42: I have heard before on a Super 60 blog that ailerons do not work particularly well on the Super 60. I had intended to make up my wings possibly with ailerons but increase the dihedral from that recommended and just use the ailerons for trimming. Alternatively I thought of mixing in rudder movement with the ailerons with the wing set to the recommended dihedral? My Super 60 repairs were almost completed last weekend with just the front canopy replacement outstanding but partially finished. Engine is re-fitted on a new ply mount and just needs a new propeller. MJE Edited By Mike Etheridge 1 on 10/07/2013 23:43:22 Hi Mike, I'm no expert on model aerodynamics (obviously) but I'd though increasing dehidral would reduce effectiveness of ailerons and that may have been the problem in the past (partially) with older Super Sixties, as they may well have had 'vintage style dehidral', ie a huge lot of it. The excess dehidral was designed to aid the 'self recoverery' of the model out of a bank and would therefore have fought against effective aileron control. My particular version shows 1/2 in at each wing tip which is not a lot. Most aircraft are flown both with rudder and ailerons, so I see no harm in mixing them on your set up if you can. Glad to hear you are re-building your 60. Cheers, Modonaut Quote Link to comment Share on other sites More sharing options...
Modonaut Posted July 11, 2013 Author Share Posted July 11, 2013 Here's a good article I found on dihedral- http://www.mnbigbirds.com/images/PDF%20Files/Dihedral_Art.pdf The problem with the Super Sixty is that it's a design that has been 'messed around' with from being originally a free flighter to then being a 3 channel R/c and then to a 4 channel r/c- all these versions would need different degrees of dihedral. Technically my wings are polyhedral as the dihedral doesn't start until two rib bays out from the centre section- but I've increased the wing tip height from 1/2 in to 5/8 in. It'll be interesting to see how it flies... Quote Link to comment Share on other sites More sharing options...
Mike Etheridge 1 Posted July 11, 2013 Share Posted July 11, 2013 Well I did think about the aileron issue but was not sure in the recent past what the problem was with the Super 60. The criticisms I read were not specific,modellers just suggested they did not like the aileron versions. About 7 years ago I bought an electric 3 channel Jamara Cessna 182 at the Sandown Park show. It was ideal to fly at the Common Broughton Gifford in Wiltshire where some of my relatives live. I noted at a later date that a 4 channel aileron version was available and so I bought one on the internet without carrying out an inspection first. Unfortunately the wing dihedral was / is the same as the 3 channel version and hence the flying characteristics of both models were much the same and there was little benefit with the ailerons, you certainly could not roll the 4 channel version but it flew OK. Now I assume you cannot / should not roll a Super 60 with ailerons? On the strength of this assumption I thought about treating an aileron wing for the Super 60 in the same light as the Cessna 182 with appropriate but more dihedral than is suggested. The Cessnas are both gathering dust in the loft. They both have suffered from stress fractures in the light foam wings and certainly the aileron wings folded up on one flight but have been repaired. MJE Quote Link to comment Share on other sites More sharing options...
Mike Etheridge 1 Posted July 11, 2013 Share Posted July 11, 2013 The 4 channel Cessna: http://www.youtube.com/watch?feature=player_detailpage&v=k5aIe30mNp0 Quote Link to comment Share on other sites More sharing options...
Modonaut Posted July 11, 2013 Author Share Posted July 11, 2013 Posted by Mike Etheridge 1 on 11/07/2013 11:15:55: Well I did think about the aileron issue but was not sure in the recent past what the problem was with the Super 60. The criticisms I read were not specific,modellers just suggested they did not like the aileron versions. About 7 years ago I bought an electric 3 channel Jamara Cessna 182 at the Sandown Park show. It was ideal to fly at the Common Broughton Gifford in Wiltshire where some of my relatives live. I noted at a later date that a 4 channel aileron version was available and so I bought one on the internet without carrying out an inspection first. Unfortunately the wing dihedral was / is the same as the 3 channel version and hence the flying characteristics of both models were much the same and there was little benefit with the ailerons, you certainly could not roll the 4 channel version but it flew OK. Now I assume you cannot / should not roll a Super 60 with ailerons? On the strength of this assumption I thought about treating an aileron wing for the Super 60 in the same light as the Cessna 182 with appropriate but more dihedral than is suggested. The Cessnas are both gathering dust in the loft. They both have suffered from stress fractures in the light foam wings and certainly the aileron wings folded up on one flight but have been repaired. MJE I don't think it's a case of should not roll, but more cannot roll, with extreme dihedral. Generally the more aerobatic a model, the less dihedral you'll find. I would guess that these kits where a 3 channel has been 'converted' to a 4 channel haven't really been tested to see if ailerons actually work properly, especially if as you say the dihedral is the same. So, if you intend in getting the ailerons to work properly don't increase the dihedral as obviously loads of dihedral was used in the early days for initial free flight stability and in early r/c as an aid coupled with rudder to execute a turn. Basically excess dihedral will fight the effectiveness of the ailerons. As I said I'm no expert, but I do know it's a complicated subject and other factors influence how an aircraft behaves- the shape of the fuselage for one thing. Lets face it the Super Sixty is quite a blundering thing with slab sides and thin, no profile tail and fin. Modonaut Judging from what happens on my Phoenix simulator with the 'high wing trainer' I wouldn't attempt to 'roll' a model with loads of dihedral anyway as height is lost very quickly during the process... In any case I don't think we were actually taking about doing an actual roll but more the effect on aileron control. On the simulator rolls are easier with the low wing trainer especially if you are quick! Edited By Modonaut on 11/07/2013 12:58:30 Quote Link to comment Share on other sites More sharing options...
Ian Skeldon 1 Posted July 11, 2013 Share Posted July 11, 2013 Hi Chaps, The reason the wing doesn't work too well with ailerons is more to do with the airfoil (Clark Y, I believe). This section doesn't lend itself too well to ailerons. A top sited spoiler working independantly on each wing might be more effective. However the charm of the Super Sixty is slow sedate flying, catching the odd thermal even and then those long finals where just the odd nudge of rudder will see it on the right path and all that's left to do then is to use throttle to maintain height etc, etc. If you really want a wing with ailerons I suggest that you use a semi symetrical airfoil and adjust the root ribs to seat onto the fuz. I did this a long time ago and was blesssed with a Super Sixty look alike which rolled very nicely but need more input throughout the flight (as you would expect). Hope the helps, Ian Quote Link to comment Share on other sites More sharing options...
Modonaut Posted July 11, 2013 Author Share Posted July 11, 2013 Posted by Ian Skeldon 1 on 11/07/2013 14:09:53: Hi Chaps, The reason the wing doesn't work too well with ailerons is more to do with the airfoil (Clark Y, I believe). This section doesn't lend itself too well to ailerons. A top sited spoiler working independantly on each wing might be more effective. However the charm of the Super Sixty is slow sedate flying, catching the odd thermal even and then those long finals where just the odd nudge of rudder will see it on the right path and all that's left to do then is to use throttle to maintain height etc, etc. If you really want a wing with ailerons I suggest that you use a semi symetrical airfoil and adjust the root ribs to seat onto the fuz. I did this a long time ago and was blesssed with a Super Sixty look alike which rolled very nicely but need more input throughout the flight (as you would expect). Hope the helps, Ian Thanks for your input Ian! Modonaut Quote Link to comment Share on other sites More sharing options...
Mike Etheridge 1 Posted July 19, 2013 Share Posted July 19, 2013 Super 60 repaired and page 21 of the BMFA news noted! Quote Link to comment Share on other sites More sharing options...
Modonaut Posted July 20, 2013 Author Share Posted July 20, 2013 Excellent- pleased to hear that! Yes, page 21,just got my copy and will read it. I must press on with my Super 60, domestic engagements and holidays will soon take their toll. Modonaut Quote Link to comment Share on other sites More sharing options...
