Mick Thompson Posted April 3, 2008 Share Posted April 3, 2008 Hihas anyone build one of these lately?. I am trying to sort the CofG on mine and am horrified at the amount of weight I'm going to have to put up front. I would appreciate if anyone has had the same problem would they post how much weight they used. I'm using 7cm as the CofG balance point and I'm upto to nearly 3 lbs of weight. The range given in the manual states 6.5-7.5cm. I know its a short nose but this is getting ridiculousCheersMick Quote Link to comment Share on other sites More sharing options...
Former Member Posted April 3, 2008 Share Posted April 3, 2008 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Mick Thompson Posted April 3, 2008 Author Share Posted April 3, 2008 Hi EricThanks for the reply, I have sorted the problem out. Easy really..read the instructions properly!!. I was taking the cg from the leading edge at the wing root instead of the WING TIP. I have now been able to put a batt up front with only 250grams of lead...big difference from over 3 lbsGoes to show your never to old to learn..or am i?Thanks Again Quote Link to comment Share on other sites More sharing options...
