Jodel Robin DR400
Sean Murphy 1
Hi to you all, at this ever helpful site. Would you give me your views on what servos to fit on this plane. I am not going to use it for tow that's one less. The manual states 9 x Standard High Torque Servo`s! Do I use different types for steering, throttle, choke & flaps? Or just one type with the same output for example 9 x Hitec HS430BH which I can see a picture of in the manual! I am fitting a petrol OS 33GT engine or gas as its known, with a choke! Is it possible to use an, on & off switch for the choke servo, so it frees up a channel, which I would wire & power independent to everything else? I will link in the servo`s where required with a "Y" lead, to hopefully use a six channel radio.
Thank you in advance, all views greatly appreciated before I go & do the wrong thing!!
Sean.
Hi to you all, can anybody help me with this? Would you give me your views on what servo`s to fit to my DR400 Ripmax Jodel Robin. It will not be used for towing so that is one less! The manual states 9 x standard high torque servo`s! Do I use different types of speed / output for steering, throttle, choke & flaps? Or should I use one type with the same output for example 9 x Hitec HS430BH which I can see a picture of in the manual! I am fitting a petrol OS 33GT engine with a choke! Is it possible to use an on & off switch for the choke servo? I would power this totally separate & would free up a radio channel if this is possible? I will link in other servo`s where possible with a "Y" lead, allowing me to use a 6 channel radio! So that's the plan any advise would be greatly appreciated.
Thanks in advance
Sean.
