Jeremy Hutchinson 2 Posted January 20, 2020 Share Posted January 20, 2020 Hi, Does anyone know where I can source aileron horns for my Wots Wot? they fit on the trailing edge of the aileron on top and bottom wings, unfortunately a tree jumped out in front of my Wots Wot and it ended up in the long grass, not too much damage but I lost a set of these aileron horns and the connecting pushrod. Quote Link to comment Share on other sites More sharing options...
Jeremy Hutchinson 2 Posted January 20, 2020 Author Share Posted January 20, 2020 I should have mentioned that my Wots Wot is from the Chris Foss kit and not the Ripmax ARTF version!! Quote Link to comment Share on other sites More sharing options...
alex nicol Posted January 20, 2020 Share Posted January 20, 2020 I had similar with a flair Christen Eagle, you don't need special control horns Use ordinary horns, reverse them ( holes to the t/e end) and fit them on the aileron t/e as close to the end as you can, fit the link rod to the bottom hole on both horns and trim off the excess control horn (hole nearest the horn locating screws) Cheers Quote Link to comment Share on other sites More sharing options...
Jeremy Hutchinson 2 Posted January 20, 2020 Author Share Posted January 20, 2020 Thanks Alex, that sounds like a good solution. Quote Link to comment Share on other sites More sharing options...
