John Gallard Posted October 7, 2008 Share Posted October 7, 2008 Have acquired a Spectrum DXi6, everything seems ok but after several attempts at binding I still have slow flashing leds on both receivers, all control surfaces and throttle are working fine. (the leds are solid when binding is completed) only on power up are they flashing. Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted October 7, 2008 Share Posted October 7, 2008 Firstly there is no such thing as a DX1...or for that matter a DXi6 - so I shall assume its a DX6i. You dont say which Rx you are using.You are doing something wrong. Read the manual very carefully about the exact procedure to follow whilst binding. Ensure the bind plug is on the battery socket, and power up with a 4 cell battery via any other Rx socket. Switch on the rx and the LEDS SHOULD BE FLASHING - then swith on the Tx with the bind switch ( trainer ) held on, and keep holding like this until leds GO SOLID. Then remove the bind plug, switch off the tx and the rx. Boot up and all should be well. Ensure the Tx is not too close to the Rx during binding. Quote Link to comment Share on other sites More sharing options...
John Gallard Posted October 7, 2008 Author Share Posted October 7, 2008 It appears the proximty of the tx and rx was the problemThanksJohn Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted October 7, 2008 Share Posted October 7, 2008 Ah good, glad you got it sorted John Quote Link to comment Share on other sites More sharing options...
