Spektrum DX6i binding problem
Geoff Bradley
Hi - I'm new to RC aircraft and have just assembled a Seagull Rising Star but am unable to bind using the DX6i. The 'BindPlug' is female and the connection on the switch harness is also female. The bind plug appears to be a loop over the two outer connections which, if so, will have no effect (I think) as there is no cable connected to one of the outer connections.
Can someone please help - so close to comleting the project but so far away ! Boo Hoo
Thanks Grant - the thread advice worked a treat.
What a brill site - my first problem solved in no time.
It's very frustrating  that  manufacturers sell products without thorough operating instructions. I've found similar with assembling the Seagull Rising Star and I purchased that because  all the reviews said it had a good instruction manual. To a complete novice it certainly was not the case.
I better go and try the engine now - fingers crossed
