MARTIN PEARSON Posted October 30, 2008 Share Posted October 30, 2008 Anyone out there found a decent muffler for the dl50 the stock exhaust is very loud...any plans for making one would be nice or to purchace one which does not cost the earth...cheers Quote Link to comment Share on other sites More sharing options...
Nobby Clarke 2 Posted October 30, 2008 Share Posted October 30, 2008 Hi Martin, Any exhaust that fits a DA will fit the DL .To get them quieter, you will probably have to use a pipe or can which costs. I use slimeline muffler on my Area 51, did improve a bit but it needs more work. I've just got hold of a pipe and can from China ,hopefully it will do the trick .what prop are you using..??What size and make..?? Paul Quote Link to comment Share on other sites More sharing options...
MARTIN PEARSON Posted October 31, 2008 Author Share Posted October 31, 2008 Hi paul ,Thanks for your reply, i am using the recommended break in prop 22-8 i chose a menz to start with but will try others, i wonder if the stock muffler could be modified in any way,they used to use wire wool in the good old days ive been told (lol) the large hole used to tighten the bolts cant help with the noise issue also, there's probably something which will fit off another engine as well,just engines have something to fit off a brison i think but thats 85 pounds,let me know how you go on with your pipe from china paul,if anyone out there has something witch is surpluss to them please let me knowMartin Quote Link to comment Share on other sites More sharing options...
Nobby Clarke 2 Posted October 31, 2008 Share Posted October 31, 2008 Hopefully weather permitting we will be doing some sound tests tomorrow on Area 51's .using Biella 22x8 Mejzlik 23x8 Vess 22 A Vess 23A graupner sonic 22x8 22x10 One with slimeline muffler, and one custom built by Weston UK i'll post results if we get the weather on our side. Paul. Quote Link to comment Share on other sites More sharing options...
