Andrew Quinn Posted November 13, 2008 Share Posted November 13, 2008 Can anybody help me i have just aquired a vmar bulldog (dismanteled) with a fuel valve not having used one of these before i am not sure how to connect it up many thanks.Andy Quote Link to comment Share on other sites More sharing options...
Former Member Posted November 13, 2008 Share Posted November 13, 2008 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Andrew Quinn Posted November 14, 2008 Author Share Posted November 14, 2008 Hi Eric there is no switching capabilities on the valve it has two nipples one at right angles at the bottom and one at about 30 degrees at the top it was originally fitted in the cowl.I have had a look at Als Hobbies web site and found one very simillar by Ripmax thanks for your help Andy. Quote Link to comment Share on other sites More sharing options...
Mike Stevens Posted November 14, 2008 Share Posted November 14, 2008 Hi AndrewThe one I am familiar with has the two angled nipples which are the inlet and outlet for the fuel.There should also be a third nipple that plugs into the front of it and is used for filling. Once complete it is removed and kept safe which then switches the valve internally so fuel flows from the tank to the carb. It could be that this valve is missing?Mike Quote Link to comment Share on other sites More sharing options...
Andrew Quinn Posted November 16, 2008 Author Share Posted November 16, 2008 Eric and Mike thankyou for tour help idid not realize when refueling the fuel feed would be closed off thanks again for your helpAndy Quote Link to comment Share on other sites More sharing options...
