John Busuttil Posted November 20, 2008 Share Posted November 20, 2008 This is an excellent review, i will be ordering the same plane asap, but you mentioned you had to modify the motor box to suit the dualsky 3536...what did you have to do? Quote Link to comment Share on other sites More sharing options...
YakMad Posted November 21, 2008 Share Posted November 21, 2008 John, If you buy the PA Thrust 20 motor which is also recommended for the Katana you will not have to modify the engine mount/box otherwise you will have to shorten the box to fit the dualsky motor, I did this on the smaller PA Katana it's easy enough. The Katana MD really is an excellent flying machine. Quote Link to comment Share on other sites More sharing options...
