Ben Mullins Posted September 1, 2009 Share Posted September 1, 2009 Hi all, Just been nosing around the Giant Cod website and found all this. There is a load of air retract stuff there and im guessing its going to be cheap, as GC always is! Is everything there that is needed for a retract setup? Ben Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted September 2, 2009 Share Posted September 2, 2009 Well yes, but be aware that most of it is only really suited to lightweight models I should add that in my experience of air systems ( and thats probably around 10 models or so over the years ) you do tend to get what you pay for. I found that much of the even moderately pricey gear was not engineered to quite the required standard, suffering from air leaks, and sloppy locking mechanisms. The mechanical integrity is especially problematic if you fly off grass - as I do - so have eventually settled on only using "Spring-Air" systems from the USA. Another component which can prove troublesome is the cheaper actuator valves.Unfortunately however, Spring Air stuff does not fit your criteria of cheapEdited By Timbo - Moderator on 02/09/2009 00:07:48 Quote Link to comment Share on other sites More sharing options...
Ben Mullins Posted September 2, 2009 Author Share Posted September 2, 2009 OK Timbo, Thanks.I had no intention of using them, I was just surprised to see them on the GC website! Think I might stick with mechanical ones for now. Quote Link to comment Share on other sites More sharing options...
