Nicholas Kay Posted December 4, 2009 Share Posted December 4, 2009 Evening all, I am hoping for some guidance from those with more Spek experience. I have a model that has been sat on the shelf a while but when I came to use it, it struggled to maintain bind. It will bind fine, connection is quick. Switch off Rx and Tx and remove the bind plug and then switch back on and then nothing, no bind. I have eleminated all connected servos, switch harness, Tx etc, nothing seems to effect this behaviour. Even completely disconnected from all servos it still looses bind after being switched off and back on. Can anyone offer help? Many thanks, Nick Quote Link to comment Share on other sites More sharing options...
Lee Smalley Posted December 4, 2009 Share Posted December 4, 2009 i have a fool proof method for dealing with AR500s ................i don't use them !!! seriously it sounds like you may have a faulty one send it back to horizon they have excellent repair service, is it an old 500 ??? Quote Link to comment Share on other sites More sharing options...
Robert Bromwich Posted December 4, 2009 Share Posted December 4, 2009 hi nick remove the bind plug before you switch anything off try that says that on no.5 on the page on binding robEdited By Robert Bromwich on 04/12/2009 21:36:30 Quote Link to comment Share on other sites More sharing options...
Nicholas Kay Posted December 4, 2009 Author Share Posted December 4, 2009 No joy, every order of bind, switch off and unplug has been tried. I am running out of alternatives. The Rx worked fine for 6 months. It has been sitting for perhaps 6 months unused. Could that have damaged the Rx? Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted December 4, 2009 Share Posted December 4, 2009 And also ensure that the bind has actually completed. despite others comments, I have no issue with any of the 4 AR500s I now use - just maidened a model today and again...absolutely no issues.Ensure that the Rx LED not only stops binking at the bind stage, but that you also wait a little longer until it glows again solid. Also remeber that the Rx can take up to 10 seconds after switching on befpore locking on to the Tx signal...this is perfectly normal, and I always double check that the controls are wiggling as expected before throwing / taking off the model. Quote Link to comment Share on other sites More sharing options...
Nicholas Kay Posted December 4, 2009 Author Share Posted December 4, 2009 Evening Timbo. I agree, never had a problem with the AR500 before in the 2 models I have. It is something with this model that has now resulted in 1 x AR500 not working altogether (I am looking for the proof of purchase so I can go back to Horizon) and this AR500 to now play up. I have tried all possible combinations of battery, harness, servo, Tx etc. There appears to be no common factor. I bind as usual, bind plug in, Rx power on, Tx power on whilst holding bind switch, await solid light on Rx, check servo movement. I then either unplug the bind then power off the Rx or power off Rx then unplug bind, neither changes the result. Could a long period of not being used somehow damage the Rx? Does it have a memory that could be damaged if not powered up often? Or perhaps damaged if suffering a short across a servo or such like? Nick Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted December 4, 2009 Share Posted December 4, 2009 Seems you have a duffer. Prolonged storage ( assuming no extreme conditions like you kept it in the oven to see when the turkey was ready ) should not affect it.Send it to HH and they will doubtless be excellent in their response. Address; Horizon Hobby UK Units 1 to 4 Ployters Road Staple Tye, Southern Way, Harlow, ESSEX CM18 7NS Quote Link to comment Share on other sites More sharing options...
Nicholas Kay Posted December 4, 2009 Author Share Posted December 4, 2009 I have already tired. No proof of purchase, no support. Understandable, but who keeps receipts for 12 months? Don't tell me, you all do! More fool me..... I will contact the shop and see if they will offer proof of purchase to help me in getting Horizon to support. Thanks, Nick Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted December 4, 2009 Share Posted December 4, 2009 You mean tried I assume. What exactly have you done with HH so far then. I think I would have simply sent it in, and said" oy this thing has stopped working mate" or words to that efffect.I sent in 3 Rx units some months back - 2 were at least 3 year old, and had been involved in bad crashes - case was split open on one, and aerial broken off the other.All parts replaced, units checked and signed off as AOK returned within 4 days. FOC. Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted December 4, 2009 Share Posted December 4, 2009 PS try a nice letter to the following, dont tell him who sent you John Norris ( jnorris at horizonhobby.co.uk ) but use the normal @ symbol >> Edited By Timbo - Administrator on 04/12/2009 23:17:24 Quote Link to comment Share on other sites More sharing options...
Nicholas Kay Posted December 5, 2009 Author Share Posted December 5, 2009 Morning All, Excellent feedback. Very helpful. Thanks for that. I will be contacting HH shortly. Quality service support is hard to find these days, support like this is rare! Kr Nick Quote Link to comment Share on other sites More sharing options...
