Posts posted by dan h
Hi David.
Those are looking really good. Yep hobbyking film is excellent stuff as you've found out. Your wing looks like the covering went on very well especially the tip!
I have just done my first ever fibreglassing job on a model. I didn't need it for strength so I went with deluxe exe kote and found it brilliant to work with. It has not added any weight to my model at all which I am really pleased about and the best bit is their is no smell to it.
Dan
Awesome build David and blog
It looks great
Dan
Number 1 the same as Bob.
Number 2 I have cut a slot in the end for a flat head screw driver to fit and hold the shaft whilst doing the nut up provided it is a normal nut and not a domed type one. Never had a problem getting the nut on and off with this slot in the end
Hi Kc
Yes that's the picture I remember, I made some the same for my latest build as I was using hard balsa spars. Like I said they worked a treat thanks for giving me the idea.
Dan
KC
have u any pics of the wooden clips you use? I remember somebody on here showing some pics of some wooden ones to hold spars in place with black screws.
I thought I'd have ago and make some turns out they worked a treat.i wonder if it was you I got the idea from.
Hi Ian.
Plaster board works very well.
Dan
That is looking very nice cliff. i look forward to seeing the end result.
Dan
Hi Matt.
What plane is it.
A 50" wingspan sports plane would need a motor bigger than the 28mm one you have it seems a bit small
Nice one martin it looks great!
Very nice steve. All that hard work was well worth it.
Dan
Hi gene.
Sounds good I have also built one of these but its not quite finished all I have left to fit is the electrics. What setup did you use?? Have you any pics
Dan
How about lindsay todds skywriter.
after I wrote my comment I had a look on tonys website. They are now available which is great.
Good luck for the maiden.
Dan
Looks absolutely brilliant! I have the freewing hawk that flys really well. I think i may have to add this to my list of build projects. Callies graphics are an excellent company i have used them.
What is the price of the kit?
Dan
Hi jim.
Yes it does have a removable backing which sometimes can be a right pita! Easy way to remove it is a piece of sellotape in a corner either side and pull apart.
Dan
All built up wings gary no foam!
following with interest also.
look forward to seeing the build pics.
i have a few builds under my belt now altho this will be a different kind of build for me.
Hi jon.
Your hurri is Looking fantastic!
Dan
Looks great gary.
finished with a nice tidy covering job
Dan.
Looks good to me.
Hi paul
I use tracing paper or grease proof paper i trace the part then pin the tracing paper to the balsa/ply etc. Then stick a pin around the outside of the lines then sand the rest to get a perfect or near perfect part. Hope that makes sense.
Dan
That black rubber looks ideal.
Think i may have a scout on ebay for that as i need some for my skywriter cockpit.... nice one gary.
Posted by Cliff Bastow on 04/05/2020 18:06:19:
I know, that always seems to happen when I download from my phone. Anyone any ideas why?
Hi cliff.
I had exactly the same problem with my pictures from my phone ( samung )
So I tried turning my pho the other way round and taking pictures and bingo every picture is the right way round now may sound strange but it works
Dan
Electric Grumpy Tigercub
in Vintage Kits, Semi-Kits and Plan Projects
Hi Chris.
Please do carry on I have been quietly following from the beginning.
This will be a very helpful thread to us newish builders looking to build a more difficult model. Yours is looking great !!!
Dan
