Mike Rollason Posted August 1, 2007 Share Posted August 1, 2007 Hi,I recently purchased a Replikit model of a Luscombe Sedan(36").This model was originally rubber powered but looks ideal for conversion to electric.If anybody has done this I would be grateful for any information in the building and converting of the kit.CheersMike Quote Link to comment Share on other sites More sharing options...
Mark Lubbock Posted August 2, 2007 Share Posted August 2, 2007 Your model is about the size that would fly well on a .5cc diesel up to a .049 glow, so I would suggest a small outrunner & 1000mah 2s lipo would be a good bet. Try a 2408-21 Bell motor/15A controller or one of the cheap combos from BRC hobbies (about £15)Your model will only need about 50W to fly well & these motors can put out over double that-just chose a prop to give you about 7-8 amps static ( 7A x 7volts + 49W & you can always throtte down if this proves to be too much)probably 7 or 8x4 for starters (the GWS slowfli props are good) At this current draw, you don't need anymore that a 10c rated pack & will spend most of the time throttled well back, giving very long flights.Incidentally, I also have a Replikit Luscombe, but this time it's the 40" Silvaire from the KK Super Scale engine powered series & I intend to go the above route with this one.Hope this helps. Quote Link to comment Share on other sites More sharing options...
