Paul Williams Posted February 27, 2010 Share Posted February 27, 2010 Hi I am struggling to see a way forward with my smoke system. I have to fit another servo to run the control valve, I only have a 6 channel radio DSX6i and already have retracts fitted and two servo ailerons so the flap channel is in use. I was thinking of useing the retract channel with a Y lead so it switches on when the wheels go up. The problem I can see is I would have no control it would be on or off . Any ideas guys Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted February 27, 2010 Share Posted February 27, 2010 I was in similar situation with a model which needed a switch for "guns" - and I simply ended up "Y" leading the two aileron servos together and using a single aileron channel, which freed up aux1. Quote Link to comment Share on other sites More sharing options...
