Lima Hotel Foxtrot Posted June 20, 2010 Share Posted June 20, 2010 Hello All, The LiPo in question is a Loong-Max Tipple 3s 1300mAH. It's brand new (sort of, I bought it at the end of February, but due to various life stuff getting in the way, have only used it for the first time today. I charged it at 1C, used it until power began to fade and put it on for another charge. At this point my Typhoon L50D Pro begins to tell me that the "Balancer Voltage too Low." The manual says: "Battery cells are short-circuited during balancing. The Pack may be faulty." Great . Does this mean I have a lemon to dispose of? I bought two of these at the same time and the other one has been fine. Suggestions welcomed, thanks! Quote Link to comment Share on other sites More sharing options...
Chris Bott - Moderator Posted June 20, 2010 Share Posted June 20, 2010 LHF have you measured the individual voltages of each cell? Quote Link to comment Share on other sites More sharing options...
Lima Hotel Foxtrot Posted June 20, 2010 Author Share Posted June 20, 2010 Certainly have, Mr. Bott. I meant to post originally, but was called to the phone. Voltages:2.742.612.64 Quote Link to comment Share on other sites More sharing options...
David Gilder Posted June 20, 2010 Share Posted June 20, 2010 Might be a daft thought but is it possible to try to run a balancing programme on it first to see if cells will balance out, if they do then try a charge again! Quote Link to comment Share on other sites More sharing options...
Andy Harris Posted June 20, 2010 Share Posted June 20, 2010 I'd say do 10 mins of gentle charge, then balance. -- You really did run those cells flat!! Set your ESC so you don't do that again! AndyEdited By Andy Harris on 20/06/2010 21:03:51 Quote Link to comment Share on other sites More sharing options...
Lima Hotel Foxtrot Posted June 20, 2010 Author Share Posted June 20, 2010 Well, that's weird. I just plugged the battery into the charger to give it a go again and it's charging and balancing fine. Also, the initial voltage in the cells came up as just under 3.5v. Honestly, if you can't fix it with gaffa tape, it's too complicated. Quote Link to comment Share on other sites More sharing options...
Chris Bott - Moderator Posted June 20, 2010 Share Posted June 20, 2010 Good news, sounds like a misdiagnosis by the charger first time around. Possible a plug not quite fully home or something. Glad it's OK though Quote Link to comment Share on other sites More sharing options...
