Ian Bradshaw Posted August 24, 2010 Share Posted August 24, 2010 Morning all, I'm currently building this model (which is a 36" 2/3 channel, sports) and I've reached the stage where I need to decide to stick with IC or convert it to electric. What are the main things that I need to take into consideration to perform a conversion? Could anybody recommend an electric set-up for such a model? Any help would be greatly appreciated. Thanks in anticpation Ian Quote Link to comment Share on other sites More sharing options...
Lee Smalley Posted August 24, 2010 Share Posted August 24, 2010 its quite a heavy model mate foam wings etc and not sure if the tank bay area is big enough for a decent sized lipo Quote Link to comment Share on other sites More sharing options...
Allan Bowker Posted August 24, 2010 Share Posted August 24, 2010 It's worth calling BRC Hobbies once you know the all up weight of the aicraft. They've helped the out many times and have been spot on. Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted August 24, 2010 Share Posted August 24, 2010 Well as its designed around a diminutive cox .049 I should think that a couple of hundred watts would be more than enough.A simple and cheap little setup like this should be fine £10 motor couple with a 15A ESC for a few pounds and a 1500 or so 3s lipo and youre away. Quote Link to comment Share on other sites More sharing options...
Lee Smalley Posted August 24, 2010 Share Posted August 24, 2010 a cox 049 will not fly it seriously mine had a os10 in it and it was gutless Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted August 24, 2010 Share Posted August 24, 2010 Ah, well not knowing the model, I was merely going by the suppliers spec / recommendation. Best wait and see what the AUW is then - but even so, a leccy version shouldnt be expensive Edited By Tim Mackey - Administrator on 24/08/2010 13:35:08 Quote Link to comment Share on other sites More sharing options...
Lee Smalley Posted August 24, 2010 Share Posted August 24, 2010 no and it should go better i would think mine was a pain the backside as the tank level was too low for the OS10 the reed induction on the 049 ws really low so for that it would have been perfect, my advice is to go ele***c , i think it will suit the model better, to make some more room in the fus for the battery i would suggest moving the aileron servo to the top of the wing using the canopy to cover it and the elevator servo at the back near the tailplane, but timbo is right it should still be cheap to get going Quote Link to comment Share on other sites More sharing options...
Ian Bradshaw Posted August 25, 2010 Author Share Posted August 25, 2010 Thanks for you thoughts and advice fellas, I appreciate it. I have no idea about electric stuff these days, things have changed massively since I used to race 1/10th offroad buggies that shared similar equipment with aircraft at that time. I guess I'll do some maths to get the AUW and then see what size cells I need to accomodate and make any necessary mods to the fuselage. Thanks again Ian Quote Link to comment Share on other sites More sharing options...
David perry 1 Posted August 25, 2010 Share Posted August 25, 2010 I've made many of these for glow, diesel and old fashioned brushed motors. The conversion to electric was to thin the wing tips by sawing through horizontally for about eight inches of each tip. Back then I used a speed 400 and eight cells and it flew very well indeed I think the worst thing you could do with a foxjet is think too much about it... It is a very sound design. Sounds like a good project, enjoy it. David Quote Link to comment Share on other sites More sharing options...
Ian Bradshaw Posted August 26, 2010 Author Share Posted August 26, 2010 Morning David, Can you explain the rartionale behind thinning the wing tips? Would this be a good mod to perform whether electric or IC powered? Cheers Ian Quote Link to comment Share on other sites More sharing options...
ff Posted February 17, 2013 Share Posted February 17, 2013 I am also putting an electric motor into a foxjet ..... Could anyone advise me where the c of g is supposed to be on this model? Thanks in advance! Quote Link to comment Share on other sites More sharing options...
