Flanker . Posted September 18, 2010 Share Posted September 18, 2010 Hi there. Any wise folk about who know if one can use a Futaba FP R 138 DF on a five cell RX pack ? I have been for a while but I wonder if it likes it. I have been having some odd airborne effects like a (one off) rudder waggle, and sudden zooms. On two occasions when dropping flapperons, and yes they are set up properly and I use them all the time. Only one control at a time seems to be affected. I wonder about voltage as there is an occasional aileron twitch that only happens or is most frequent when the batt is fresh and often at around 7,2 volts. I have not been able to obtain any odd stuff from any surface except for the little ail twitch on the ground. Turbulence is possible but this would be a first that I have noticed have an effect like this. (she wagged her tail like a dog on climb put, wings level, and on subsequent take off tshe zoomed on lift off, responded correctly and proportionately to down and flew on ) Any thoughts? Ta, Flanker Quote Link to comment Share on other sites More sharing options...
Big Bandit Posted September 19, 2010 Share Posted September 19, 2010 Flanker, We did it all of the time with the old M series with no problems, but not tried it with the newish gear. I'll have a look on the Futaba site. Cheers, Chris. Edited By Big Bandit on 19/09/2010 10:44:48 Quote Link to comment Share on other sites More sharing options...
Big Bandit Posted September 19, 2010 Share Posted September 19, 2010 Flanker, Checked out the site and it looks OK to use 6 volts. http://www.futabarc.com/faq/faq-receivers.html#q732 Cheers, Chris. Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted September 19, 2010 Share Posted September 19, 2010 Its normally servos ( some ) which dont like the higher voltage - not the rx. Quote Link to comment Share on other sites More sharing options...
Big Bandit Posted September 19, 2010 Share Posted September 19, 2010 Tim, Spot on but Futaba warn against using a higher voltage as it can reduce the useful life of servo's, although I think these days most servo's will or are made to use 6 volts. Have you had any dealings with the new digital servo's from Overlander, just brought two to try in the gangster for ailerons. Chris. Edited By Big Bandit on 19/09/2010 12:27:20 Quote Link to comment Share on other sites More sharing options...
