Kevin Russell Posted October 3, 2010 Share Posted October 3, 2010 Hi I have decided to ditch my DX7 transmitter and buy a DM8 module for my FF9 it binds OK but if I turn the TX off the servos just loose power, its the same on both a AR6200 & AR500 receivers, I thought the fail-safe should power the servos back to the bound position?Kevin Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted October 3, 2010 Share Posted October 3, 2010 I think you will find that the spektrum receivers only have fail safe on throttle - and even then this needs to be established at the time of binding. Quote Link to comment Share on other sites More sharing options...
Kevin Russell Posted October 3, 2010 Author Share Posted October 3, 2010 dam just found this should have googled a bit better If the receiver is turned on first (except for the AR500, AR6100 and the AR7100 receivers), all servos except for the throttle will be driven to their preset failsafe positions set during binding Note: When using the AR500, AR6100 or the AR7100, if the receiver is turned on first, no outputpulses are sent to any channels. Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted October 3, 2010 Share Posted October 3, 2010 I think you will STILL find that many of the spekky receivers only actually drive the throttle servo to any so called preset failsafe position - despite the blurb. Quote Link to comment Share on other sites More sharing options...
Kevin Russell Posted October 3, 2010 Author Share Posted October 3, 2010 seem like all the ones I have behave the same AR7000 Ar6200 AR500 so you could be right Quote Link to comment Share on other sites More sharing options...
