David Gilder Posted December 21, 2010 Share Posted December 21, 2010 After Matts input, I thought that I would put a few pics on of my new model for 2011 season!!! (xmas present from my better half!!) Introducing my T45 GOSHAWK...... This is just a dry fit hence the decals not put on!!! Wheels are only fitted to see what it looked like with them on!!! Dave. Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted December 21, 2010 Share Posted December 21, 2010 Sweet.... just for the slope Dave? What model is it, span and weight etc?? Quote Link to comment Share on other sites More sharing options...
David Gilder Posted December 22, 2010 Author Share Posted December 22, 2010 Timbo, The spec for this is as follows: Wingspan: 950mm Length: 1000mmWing loading: 36g/dm2Main wing area: 18sq/dmFlying Weight: 620g Here is a LINK to the model itself in the HobbyKing website!! I am of course open to advice on adjustments and build advice for this as never built / flown a foam model before!!! (like how best to get rid of little nobbly bits all over it from the moulding process!!!!) Cheers, Dave. Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted December 22, 2010 Share Posted December 22, 2010 Ah, thought it might be that one The moulding pips and bumps should only be removed if you are considering covering and painting it. If so, then a light sanding with fine emery paper will remove them, fill any holes with spackle ( very lightweight filler ) and for covering, I use tissue and Poly-C or for tougher finish but at a weight penalty light glass cloth, and again Poly-C or maybe epoxy resin.If your gonna just slope it, then I would leave the fan etc out, and then you can afford more weight for tougher coverings. Quote Link to comment Share on other sites More sharing options...
David Gilder Posted December 22, 2010 Author Share Posted December 22, 2010 Just a thought, If it is going to be so light anyway, do I really need to put a harder covering on it? Landings should be quite soft anyway!!!! I might lightly sand of the pips on the white portion of the foam, but I have no experience or equipment for re-painting the red areas if I were to sand them down!!! Dave Quote Link to comment Share on other sites More sharing options...
