Steve Fish Posted February 1, 2011 Share Posted February 1, 2011 There may be another thread on this but I failed to find it. Relocate, moderator, if required! I read with interest the review by GA.As an owner of the tried and trusted (imho) Spektrum DX7 I was struck by the similar, if not identical transmitter case moulding, the same switches placed similarly, the same text and font. Funny that JR's tag line is "Feel the Difference". It's different - but the same? Granted the screen is backlit and there's a rolling selector but Spektrum have that on more recent models. NZ prices are higher on the whole, so cannot comment really, but £330 sounds much more than a DX7 set. For fewer model memories. Quote Link to comment Share on other sites More sharing options...
Lee Smalley Posted February 1, 2011 Share Posted February 1, 2011 Tony the DX7 was only a JR transmitter with the DSM2 protocol installed by spektrum, The feel the the difference tag is JRs ergonomic design philosophy, i think you will find that the DX7 actually had little to do with Spektrum, that is why txs made specifically by spektrum look and feel so different the XG7 is JR first true Freq Hopping system and a seperation from Spektrums DSM2 as a result they have released it first on a mid range system (on a tx that has been available in the US for some time) and thats a wise idea there are plenty of people that like me are genuine JR fans and do not like the DSM2 protocol Quote Link to comment Share on other sites More sharing options...
David Chapman 5 Posted November 22, 2020 Share Posted November 22, 2020 Hi all....trying to set up a throttle safety dis-arm using the Aux 2 switch. Can anyone help please! Am familiar with “System Mode” and “Device Select” etc....but still no go. Be most grateful!! Safe flying Dave. Quote Link to comment Share on other sites More sharing options...
Former Member Posted November 22, 2020 Share Posted November 22, 2020 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
David Chapman 5 Posted November 22, 2020 Share Posted November 22, 2020 Thanks for quick reply Steve. The problem I have is trying to allocate the Aux2 switch! I have it working but only with other default switches. Sure I’ll sort it soon...somehow! Quote Link to comment Share on other sites More sharing options...
Peter Jenkins Posted November 22, 2020 Share Posted November 22, 2020 David, if you are using a JR XG series Tx, the THRO HOLD function is the most convenient. Allocate the AUX2 switch and set the figure to -5 or more. Check that the fig you select is sufficient to kill a running motor and you're done. Don't use the THRO CURVE for that. I use the throttle curve for setting an idle. Quote Link to comment Share on other sites More sharing options...
David Chapman 5 Posted November 22, 2020 Share Posted November 22, 2020 Hello Peter, unless you know better, it appears throttle hold is only available in Heli mode....so can’t use it! But thanks for response, regds Dave. Quote Link to comment Share on other sites More sharing options...
