Michael Graff Posted September 27, 2007 Share Posted September 27, 2007 Hi all, I bought a CMP 120 size P-47 a couple a weeks ago.It looked very nice in the box and even more so when i started to examine it closer.There was a couple of things that I couldn´t relly live with, and that was the canopy (it looked as something that would be fitted on a Lloyd...) and the hinges, I don´t fancy those fuzzy hinges. The plane is already painted in a camouflage, consisting of olive drab / light olive drab and neutral grey on the underside. I wasn´t sure how fuelproof it was but when I tested some different kinds of solvents on it, I can only think it is some kind of matte epoxipaint. I didn´t want to use the decals provided as I don´t think they would adhere well on the matte paint. Instead I painted it to resemble a SEAC P-47. I painted on the markings with standard Tamiya paint, a Vargas pinup was added as I don´t think a warbird is complete without one. I clearcoated the entire airframe with Sikkens 2-K matte clear ( total amount of clear used: 1,2 dl). I made a new canopy of some 0,4 mm plywood and some clear plastic. I opted for pneumatic retracts so a pair of Spring-Air retracts was installed. I modified the hard points as they wasn´t up to the job. The engine I use is a Moki 23cc petrol engine. All up weight is a bit heavier than stated on the box, 5,3 Kg as opposed to 4-4,5 Kg. The test flight revealed that it is a really good flyer. Very stable and nice. I have the C of G at 11 cm (the instructions say 12-13 cm) and will put it a bit more to the rear. A very nice warbird that is a good value. A few pics I took before the maiden flight: Quote Link to comment Share on other sites More sharing options...
David Ashby - Moderator Posted September 28, 2007 Share Posted September 28, 2007 Very nice Michael, not a kit I'm familiar with so thanks for sharing.Davidps.....are you going to pop some bigger wheels on her Quote Link to comment Share on other sites More sharing options...
Michael Graff Posted September 30, 2007 Author Share Posted September 30, 2007 The wheels are to be replaced with some Robart 90mm´s, they are on backorder unfortunately. Quote Link to comment Share on other sites More sharing options...
