Martin Whybrow Posted May 24, 2011 Share Posted May 24, 2011 I'm using some SLEC spring fuel pipe clips to make sure my fuel pipes don't come adrift, particularly on the sections that have parallel wall pipes (I've run small copper tubes through the firewall to avoid overly-large holes for the fuel pipes). The problem I'm having is that the clips seem to be designed for thin walled fuel tubing, but all the stuff I have is thick walled (about 5.5mm OD); the clips can be opened far enough but it's very tricky, they tend to squirm if I use needle-nose pliers to open them. What do you use (either to open these or alternative clips)?Edited By Martin Whybrow on 24/05/2011 23:52:36 Quote Link to comment Share on other sites More sharing options...
Spice Cat Posted May 25, 2011 Share Posted May 25, 2011 Where access allows, I use a set of mini pliers but watch out they are real finger nippers. Quote Link to comment Share on other sites More sharing options...
