Paul Williams Posted November 7, 2011 Share Posted November 7, 2011 I have acquired a second hand 80" edge 540t does anyone know the distance back from the leading edge for the balance point please. Quote Link to comment Share on other sites More sharing options...
GONZO Posted November 7, 2011 Share Posted November 7, 2011 If its the CMPro one go to this THREAD and somewhere in there it will tell you about the holes that are cut in the horizontal side frame that the cockpit sits on. These are suposed to indicate the range of CG settings. But, it would appear that things went a bit wrong and they are all set to far back, about 1"+. IIRC about 1/4" in front of the first hole was recomended, but CHECK. The thread also gives other recomendations on throw and expo settings. HTH Quote Link to comment Share on other sites More sharing options...
