Building a MAG1548 Apollo glider
John Armstrong 2
I have recently bought a copy of the RCM&E Apollo V tail glider. Has anyone out there any experience of this build? Did they modify this from the original plans in any way? I cannot see anywhere on the plan where the C of G should be. As I intend to update the motor and battery to current technology I would like to have some clue where the C of G should be. Any suggestions would be much appreciated.
  • 8 months later...
I have just finished my Apollo as plan. The C of G should be max 60mm from the leading edge.
The only mods were to suit the motor from a foame WOT4 and making sure my 2200 3s lipo would fit in the nose section which also required approx 60grams of extra nose weight.
Only had 1 test flight and needs more playing around with nose weights.
Check the 'V' tail setup with regard stick movement before putting up, very easy to get wrong way round.
Set ESC to breaked otherwise the prop stays spining and produces drag.
Mike
