The Triplane/s build thread
ASHLEY YOUNG
hi all. looks like very nice template by Rafa L to fix the struts on the sopwith. you might be interested in  the following data that ended up with my sopwith balancing just right.
motor pot50 weight about 35g with 8x4 pot folder
1250 lipo 7.4v weight 54g
2x titch servos about 5g each
gws nano rx 4 about 9g
fly 12a esc very light weight.
all up flying weight of aircraft 244g  8.625oz.
these parts were available to me from a previous plane and alternative cheaper items would probably do providing weight is kept as low as possible.   Can anyone report on their flying experience with this Sopwith?
Hi Donnie...to be truthful, I havent even got around to doing the wings yet - have been a little distracted with other things. Just finished the fus last night, all radio gear in, undercarriage finished, wheels and tyres made up from old mouse mat, battery hatch and fixings etc.....had a bit of fun running it around the lounge floor - pulls a bit to the right ( axle obviously slightly out of alignment ) but ruddder corrects it OK. I havent bothered with the side cheeks
Heres the latest pictures.
I am hoping to get on with the wings tomorrow, following your cut and glue method.
http://i36.photobucket.com/albums/e10/eunos800/SL270455.jpg
http://i36.photobucket.com/albums/e10/eunos800/SL270454.jpg
Hi Wess,
Cyril's model was 177gr. Yours is a bit heavier, but well powered. Have you flown it? I hope your plane to be a great flyer.  SOPWITH- I made a ply (1/16) frame to reinforce the bottom deprom sheet, just where U/C legs and servo will seat.
http://i260.photobucket.com/albums/ii38/nireargazkiak_2007/sop-89.jpg
hi Rafa L. that reinforcing frame looks really good and has the advantage that more space becomes available for the pack which is needed as mine is a bit tight.  u seem to have used depron side cheeks where-as i used 0.8mm here.
i must admit that since xmas the winds here have been too much for this little bird, but i have had a couple of flights and must say i am tickled pink with the performance.  if u have ever flown a gws tiger-moth the SOPWITH flies very much the same. even at the slightly overweight of my model.     hand launch here as the grass is too long but she flies out of the hand with a gentle launch and stooges about with what i think is the right sit namely slightly nose up.      easy turns did not drop a wing and i found the outing rather good.
i am sure u will be pleased when u come to fly your model.  nb i do try very carefully to get the balance point right on the C of G
happy hours
Any Australian reader looking to make either or both the Triplanes and have been unable to locate a suitable sized soft-drink bottle to make the cowls should check out the cleaning section in the local supermarkets.
The l litre size bottles of kerosene, methylated spirits and turpentine is the right diameter and shape. (Of course, the kerosene bottles are coloured blue and might be a bit hard to paint over.)
Coles and Safeway/Woolworths have these bottles under their own house brands as well as by other suppliers.
Hope this information is helpful.
As for me I am waiting on stocks of 2mm and 3mm Depron to arrive from the Australian agents - some 3,000 kilometres away!
Thanks to all those above who have posted their solutions to construction difficulties. It will come in handy for when I start cutting and gluing.
Murray
To transfer parts accurately from a plan this might be a helpful tip and much easier than making card templates.
I usually go to a local print shop and get them to make two or three copies of the plan. I then roughly cut out the shapes slightly oversize and mount them on the depron or balsa using 3M Spray mount. You can the cut round with a sharp knife and get perfect parts. The paper template can then be easily peeled off or, in the case of the Fokker formers for example, left in place to strengthen the depron.
 This also keeps the original plan clean for future use.
donnie eskew; Loaded a pic of my DR1 at its present stage. You will find it in Gallery. I have chosen to model Fok DR1 127/17 ( works No. 1838) of Jasta 11. not certain of the rudder colour, but as it was BvR's mount, I felt it should be red. Still a fair amount of detail to add.
Wings now done, using slit and glue method, seems to have worked OK although top surface does reflect where the lengthwise cuts were made. This does not bother me unduly, and will have little effect if any on its performance. Just have to decide now on best methosd to ensure they are attached correctly, with correct incidence and dihedral. I am thinking the card jig idea may be best.
Pictures later.....
Timbo
I am glad that this method worked.
I have never heard of the card jig , could you give me a little more Info or some pic's of
this jig.
Do you know if any of the  guy's are building the Bloody Mary, or are thinking about it.
I think I have all the plans for her now. If anyone has any input or some info it would be great.
Thank Donnie
I don't think the spanwise slits are necessary or were even intended by Cyril. The Depron sheet has a natural tendency to bend in one direction. ( usually along the width rather than the length.) So the wings are cut out ACROSS the sheet, not ALONG the sheet. Cyril doesn't show us how the curve is induced, but there are some intriguing photographs in the new Walrus build in the Gallery. The pictures are by RCM&E and, typically, there is no explanation. ( Moan. Moan...) I found that gently rolling each wing over the radiused edge of a table, produced a curve very like that shown in Cyril's plan, and the form has stayed. Always bearing in mind, that a lot of Depron models have just flat sheet wings.
Well I have done mine now, and have no more depron left. They seem to have come out fine,albeit with a bit more curvature than some of the photos I have seen. I am not too worried about this, as I reckon it will merely provide a better airfoil /lift shape. I filled in any remaining evidence of the spanwise slits with some superlight filler ( spackle as the yanks call it ) Pictures below.
I am just working on the tail rigging now - not easy especially with my less than nimble fingers
Then I have to tackle the fitting of the wings to fus, and rigging those. NOT looking forward to it I must say, as I still haven't really deciphered the method for ensuring symmetry, dihedral and incidence angles. Anymore photos or info on how the Jig idea was used to alighn things up, or am I just being too fussy, and should just get on and stick them on using my pretty accurate eyeballing method ?
http://i36.photobucket.com/albums/e10/eunos800/tail.jpg
http://i36.photobucket.com/albums/e10/eunos800/top.jpg
http://i36.photobucket.com/albums/e10/eunos800/under.jpg
 Timbo
I think you did a great job,the wings look very good.
The little over curve should give better lift.
A little sand paper, spackle,and paint will do wonders with foam.
How are you going to make that card jig, and out of what material.
Just wanted to compare your's to what I am thinking about and find the easiest way
to git-r-done.
Keep up the good work.                                       Donnie
Hi Donnie, decided the jig was going to be more work than the job of fitting them ! Lazy me therefore has gone ahead and used the old " eyeball it " method. All now loosely test fitted with cocktail sticks, and tomorrow I will do the interplane struts and then tackle the rigging before gluing with PU gorilla.
Incidentally, I found the top wing centre section was a mile too small in width on the plan.
I have used 6mm on top wing ( as I reckon this will be the handle ) and 3mm for the others.
Will post pictures of todays work later tonight ( been flying too ) so not a lot of progress - I am slow builder anyway
Hi pals: Nice to know that Wess' plane is such a good flyer. I hope the mine will be too. Now I'm working on the U/C and wheels of the Triple. For the U/C's axle I used 1,5 mm CF rod. By the way, can anyone tell me how much is 20 SWG in metric?… or …Where can I find a SWG / metric conversion table?
http://i260.photobucket.com/albums/ii38/nireargazkiak_2007/ep-sopwith%20triplane/sop-117.jpg
I used sewing thread to reinforce the U/C legs' junction.
http://i260.photobucket.com/albums/ii38/nireargazkiak_2007/ep-sopwith%20triplane/sop-118.jpg
For the wheels I used 50x3 mm O-rings and the hub is a sandwich ply(1/16) + deprom(1,5mm- 3mm sanded-) + ply.
http://i260.photobucket.com/albums/ii38/nireargazkiak_2007/ep-sopwith%20triplane/sop-125.jpg
Progress has been slow due to laziness and good sloping weather . However, heres the story so far..... just the rudder to paint, and then wings to finally tackle attachment and rigging. I will probably test fly her before I bother with the dummy radial engine and pilot, but if she is sweet, then I shall definately be doing both engine and pilot. I HATE empty cockpits.
http://i36.photobucket.com/albums/e10/eunos800/triplane1.jpg
http://i36.photobucket.com/albums/e10/eunos800/triplane2.jpg
