anthony dodson Posted January 15, 2012 Share Posted January 15, 2012 hi ive just put together an indoor mini piaget 3d ive used all the recommended parts but when i throttle up the motor runs fine till i throttle back then try to open up again to which the motor just judders and wont run on feeling the motor it feels red hot so i suspect over proping but im using the recommended, its a c10 motor ,turnigy 6 amp controller on a 2 cell lipo with a 5x3 prop. can any one help!!!! Quote Link to comment Share on other sites More sharing options...
Del Wheatley Posted January 15, 2012 Share Posted January 15, 2012 i've just been through a similar prob,bought a complete set up,the motor ran once then would just judder,turned out to be a faulty brand new motor.Edited By Del Wheatley on 15/01/2012 12:27:02 Quote Link to comment Share on other sites More sharing options...
anthony dodson Posted January 15, 2012 Author Share Posted January 15, 2012 oh right i am starting to wonder bought all this kit through hobby king so probably gonna be a problem to return i may have to bite the bullet and buy again!! Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted January 15, 2012 Share Posted January 15, 2012 Check all your connections are sound, and that nothing is binding. You could also try lowering the ESC timing and see if that helps. Have you got a wattmeter? Quote Link to comment Share on other sites More sharing options...
anthony dodson Posted January 15, 2012 Author Share Posted January 15, 2012 no i havent i know a mate who has one,in what respect do you mean lower the timing on speedo this is all double dutch to me lol Quote Link to comment Share on other sites More sharing options...
Ben B Posted January 15, 2012 Share Posted January 15, 2012 I'd also suspect timing. Did the ESC come with a timing card? If not I'd get one, trying to program via the transmitter is a pain! Quote Link to comment Share on other sites More sharing options...
anthony dodson Posted January 15, 2012 Author Share Posted January 15, 2012 no it didnt come with a programme card reading instructions all the bleeps when on start up seem to be correct for a 2's lipo i went into the timing programme i think ive set it to low but still doing the same the motor is red hot the controller has got a shut off mode if its overheating so maybe its that??? with the prop off the motor will run without the problem??? Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted January 15, 2012 Share Posted January 15, 2012 The motor can be run with no prop ( advisable anyway when setting up )If youve checked all the other things suggested...then it sounds as though you may have a duff motor - assuming its not overpropped. Quote Link to comment Share on other sites More sharing options...
anthony dodson Posted January 15, 2012 Author Share Posted January 15, 2012 right i was hoping it maybe something i could correct! Edited By Tim Mackey on 15/01/2012 14:30:12 Quote Link to comment Share on other sites More sharing options...
