Richard Wicker Posted December 16, 2007 Share Posted December 16, 2007 Hi people.When building a WW1 type with scale wing section, is there a fool proof way of rigging up a closed loop system (or a dummy one) without having an unsightly push rod showing under the wing to the control horn?Richard. Quote Link to comment Share on other sites More sharing options...
Former Member Posted December 18, 2007 Share Posted December 18, 2007 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Tony Patman Posted February 14, 2008 Share Posted February 14, 2008 In David Boddington's book there is a diagram of a hidden aileron mechanism which I think is different from Eric's suggestion as I don't think it involves sliders. A hinge is fixed in the leading edge of the aileron at an angle off the plane of the aileron. A rod is attached to the other flap of the hinge, which protrudes inside the wing. As the rod is moved side-to-side, the aileron, by virtue of the angle at which the hinge is fixed, pivots up and down. The rod can therefore be actuated by a push-rod at right angles to it down the wing, either from a central servo or from a dedicated one closer to save a long rod run. I suppose you'd use a ball-link to connect them, as I think the rod attached to the hinge would need to pivot relative to the main push-rod. Anyway, the mechanism shouldn't be any fatter than the aileron itself, and can be concealed entirely within the wing without the need for any horns or push-rods protruding outside. It was a challenge to figure out the spacial transformations involved. After a period of waving my hands around in strange configurations, I kind-of succeeded in visualising the motion, but I have a vague intention to build a mock-up at some point just to see how it works before trying it in a model. If anyone beats me to this, or has an implementation already, I'd be interested to see some pictures. Quote Link to comment Share on other sites More sharing options...
Evan Pimm Posted February 15, 2008 Share Posted February 15, 2008 Or else you could just use cables from the servo hidden in the wing, these cables exiting the wing in the scale position and operating the aileron in the usual 'pull-pull' fashion...bit like a rudder on its side, if you get the drift...Evan. Quote Link to comment Share on other sites More sharing options...
Bob Cotsford Posted February 15, 2008 Share Posted February 15, 2008 servo in the bottom wing pulling on the lower wing ailerons via bottom mounted horns, top and bottom wing ailerons connected as per full size, and another cable joining the top wing ailerons via top mounted horns to complete the closed loop. Use a spring in the top wing run to take up any slack. Depending on scale you could even run the cables through scale pullies to go from spanwise to chordwise runs. Quote Link to comment Share on other sites More sharing options...
Richard Wicker Posted February 23, 2008 Author Share Posted February 23, 2008 Thanks to everyone for the advise on this one.With regard to scale, it would be 1/4 but all information i have about scale pulleys report problems with slop. Has this problem now been solved with up to date materials etc, as i do admit a lot of my books, magazines etc are a bit dated. Quote Link to comment Share on other sites More sharing options...
Bob Cotsford Posted February 23, 2008 Share Posted February 23, 2008 a spring in the top wing run, to eliminate slop? A bit of trial and error would be needed to get the right strength spring and the right amount of pre-tensioning. Quote Link to comment Share on other sites More sharing options...
Former Member Posted February 24, 2008 Share Posted February 24, 2008 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Rob Cope Posted July 19, 2008 Share Posted July 19, 2008 Hi All,No experience here, but perhaps a tensioner spring pulling the line out of straight between two hard points would be good - similar to a car engine cam chain tensioner sprocket. Then you can provide various anchor points and use the appropriate one rather than having to tie off the line at exactly the right length on the spring. Maybe even tie the far end of the spring - but with far better tension control owing to the angles. Pulleys or beeswax may be needed to provide for smooth running. Any good?Regards, Rob Quote Link to comment Share on other sites More sharing options...
Yorkman Posted July 20, 2008 Share Posted July 20, 2008 Tony Patman wrote (see)In David Boddington's book there is a diagram of a hidden aileron mechanism which I think is different from Eric's suggestion as I don't think it involves sliders. A hinge is fixed in the leading edge of the aileron at an angle off the plane of the aileron. A rod is attached to the other flap of the hinge, which protrudes inside the wing. As the rod is moved side-to-side, the aileron, by virtue of the angle at which the hinge is fixed, pivots up and down. The rod can therefore be actuated by a push-rod at right angles to it down the wing, either from a central servo or from a dedicated one closer to save a long rod run. I suppose you'd use a ball-link to connect them, as I think the rod attached to the hinge would need to pivot relative to the main push-rod. Anyway, the mechanism shouldn't be any fatter than the aileron itself, and can be concealed entirely within the wing without the need for any horns or push-rods protruding outside. It was a challenge to figure out the spacial transformations involved. After a period of waving my hands around in strange configurations, I kind-of succeeded in visualising the motion, but I have a vague intention to build a mock-up at some point just to see how it works before trying it in a model. If anyone beats me to this, or has an implementation already, I'd be interested to see some pictures. first seen (by me) operating the ailerons of the HP Victor-which had a fairly substantial ball-with-a-hole-in sliding in a block in the t/e driving a hefty rod into the angled hinge-worked on that!My York has a variation on the theme-pushrod parallel to the t/e bent in an open 'z' with a split pin head riding over it-as it moves from the bottom to the top of the 'z' it pivots the aileron down,and vice versa. Quote Link to comment Share on other sites More sharing options...
Terence Lynock Posted September 5, 2008 Share Posted September 5, 2008 Small 4mm brass pully's are available from www.model-dockyard.com, they are usually used for rigging ships masts but could be used to rig hayleyrons etc, regards. Quote Link to comment Share on other sites More sharing options...
