Dinged Diamond 2500
Did it again. Lack of concentration, human error or pure stupidity; prepped the Diamond 2500 for flight but didn't carry out pre flight checks of the control surface. The ailerons were incorrectly wired in and the result was this;
I may just buy another fuze but it's £61.
Now, with regards to the broken flap; how is the best way to reattach??
Your thoughts please.
How is it hinged as standard SC.....just with a very thin section of the wing foam?
If so I would just cut it free, true up the surface with a sanding block & fit "normal" hinges. I would be tempted to use the "pin & leaf" type hinges rather than the furry cyano ones & use Epoxy to fix them (cover the hinge point in vaseline or similar to keep the glue out) & then maybe peg them with a cocktail stick if your paranoia becomes too great.....wink 2
I might be tempted to do the other side whilst you're at it too in the interests of similar movement for both flaps.....
Having finished and fired up the electrics, I am wanting to make a few cosmetic improvements.
I have sanded parts of the fuze where the glue escaped. In doing so I have taken the shine off the outside and left a slightly rough surface to the foam. Is there anything I can use to seal this back in and bring back the shine??
Regards.
