Rimmerrail Posted June 7, 2012 Share Posted June 7, 2012 Could someone please tell me the difference between the hacker x-40 and the x-40 SB pro please. Quote Link to comment Share on other sites More sharing options...
James M Posted June 7, 2012 Share Posted June 7, 2012 Hi The SB on an ESC usually indicates that it has a switched bec as opposed to a linear bec. Switched becs usually give more current and voltage to the radio gear, as well as producing less heat. Have a look at the following on link wiki as to the differences between linear and switching voltage regulators. A bec just a voltage regulator by another name! Quote Link to comment Share on other sites More sharing options...
Rimmerrail Posted June 7, 2012 Author Share Posted June 7, 2012 Thanks for that, my next question is do I have to have a separate bec(voltage regulator) if I only have the hacker x-40? Quote Link to comment Share on other sites More sharing options...
James M Posted June 8, 2012 Share Posted June 8, 2012 You shouldn't do - most linear becs will handle 3-4 servos with adequate cooling. As a guide the following is usually seen on esc to determine the type of bec they have - "nothing!" usually a linear bec, but not always. "SB" Switched/switching Bec "Opto" No bec - needs a separate bec/voltage regulator. But I'd always, always say that reading the manual is the only way to be sure for sure! Quote Link to comment Share on other sites More sharing options...
Rimmerrail Posted June 8, 2012 Author Share Posted June 8, 2012 Thanks for your help james Quote Link to comment Share on other sites More sharing options...
