John Sheehy Posted September 18, 2012 Share Posted September 18, 2012 A great deal of my RC modelling life seems to be waiting for packages from HK. I'm currently waiting for, among other things, the RX3s stabiliser under discussion and a wireless buddybox system. This system uses two receivers onboard and two transmitters on the ground, switchable by the master Tx. When these items arrive I can fly to a safe height on a bare Rx and then switch over to the stabilised Rx. If you have the space this seems like a safe way of setting up. The buddybox was originally intended for checking a suspect Rx Quote Link to comment Share on other sites More sharing options...
Chris Bott - Moderator Posted October 5, 2012 Author Share Posted October 5, 2012 I had a good go yesterday with the Orange one again. This time very solidly strapped down so it couldn't move in any way other than with the aircraft movement. I have to say I'm still not impressed. It was pretty blustery a and windy. At some speeds it seemd to be helping keep the model stable but at times the model was moving as if affected by glitches. I tried three flights on ever lowering gain settings and it didn't ever fill me with any confidence. Other clubmates were quite impressed with a 50p shaped loop I did On the other hand, I did some tests a while ago in the same model with the 3 axis board frok HK - the bare circuit board one. Now that one really did make the model nice and stable in blustery conditions. So my next move will be to put that one back in just to confirm that it actually does help as I remember it did. Quote Link to comment Share on other sites More sharing options...
PETER BRUCE - Eastchurch Gap Posted October 10, 2012 Share Posted October 10, 2012 Hi all. I have been posting elsewhere on this forum about using a very simple gyro fitted to the rudder and I have now posted two videos which show the plane rudder control surfaces with on-board video camera. This thread is much more involved as my intention was to just "keep it very simple" however the use of an on-board video camera showing whats going on with the control surfaces helps a lot - even a key fob camera is a help. Just an observation. Regards Peter Quote Link to comment Share on other sites More sharing options...
Chris Bott - Moderator Posted October 10, 2012 Author Share Posted October 10, 2012 Hi Peter, yes I was impressed by ho much you could tell from your camera. Of course you have to be confident you can remember which are your inputs and which are from the stabiliser, but it definately looked a useful technique. Quote Link to comment Share on other sites More sharing options...
Radge Posted November 29, 2012 Share Posted November 29, 2012 HK have released Version 2 from the global warehouse .**LINK** It has VTail and Delta capability also an Aux channel which should enable an on/off inflight facility I should imagine. Quote Link to comment Share on other sites More sharing options...
simpson j Posted January 5, 2013 Share Posted January 5, 2013 Hi may 3axis will not work on ailerons but will work on elevator & rudder ? sent emails hobbyking ? john Quote Link to comment Share on other sites More sharing options...
Giuseppe Saroli Posted October 27, 2014 Share Posted October 27, 2014 Help please I got a the 3 axis v2 and tested on my futaba f6 35 MHz and it works perfect no problem but on my hitech 2.4 gz radio I am only getting the gyro to work that is when I move/shake the the 3 axis module all 3 servos work accordingly but I have no response on the sticks even with aux switch off basically I have no control of it hope I have explained properly am I doing something wrong or is my hitech not compatible with it Thanks in advance Quote Link to comment Share on other sites More sharing options...
