Piper Cub Posted January 6, 2008 Share Posted January 6, 2008 Does anyone know of a reliable, compatible Futaba Tx & Rx charger where both outputs are better than 120mah?With Tx & Rx batteries now in the region of 2500mah, even a 120mah charge rate takes over 20 hours to fully charge! Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted January 6, 2008 Share Posted January 6, 2008 Why not use a "proper" charger like a pro peak prodigy or similar. This will charge all your batteries including the tr and rcvr ones, lead acid field box batteries, nickel AND LiPo flight packs, discharges and cycles etc etc....Simple enough to put the right style connector plugs etc on .example Quote Link to comment Share on other sites More sharing options...
