Ian Rayne Posted August 27, 2012 Share Posted August 27, 2012 I'm repairing a wing I slightly damaged this weekend and there is polystyrene under the balsa, is there a special glue you use to glue balsa onto polystyrene or will the normal two part epoxy work Thanks Ian Quote Link to comment Share on other sites More sharing options...
Mark Powell 2 Posted August 27, 2012 Share Posted August 27, 2012 Epoxy will do. In fact the 'best' builders of foam wings, individuals or ARTF manufacturers, use epoxy to stick the balsa on. Quote Link to comment Share on other sites More sharing options...
Ian Rayne Posted August 27, 2012 Author Share Posted August 27, 2012 Thanks Mark I did not want it to melt away under my nose because of my stupidity . Ian Quote Link to comment Share on other sites More sharing options...
