Former Member Posted February 27, 2008 Share Posted February 27, 2008 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted February 28, 2008 Share Posted February 28, 2008 Heres a couple for starters....AXI ( Not cheap cheap, but not as bad as the Muton death ray gun ) 22/12/20 goldline on 3s and 10 x 5BRC cheapie ( 17 quid ) here"250 watt motor, happy on 3s and 10 " prop etc.Depends really on what sort of power you want. If its the model belowThen you are looking at around 1.5 lbs AUW I beleive, so aim for around 150 watts per pound for sprightly performance, therefore you need about 225 Watts.... or more if you want to really be ballistic. Quote Link to comment Share on other sites More sharing options...
Former Member Posted February 28, 2008 Author Share Posted February 28, 2008 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted February 28, 2008 Share Posted February 28, 2008 I think then that this model you have is smaller and lighter. Span works out at 40 inches, and weight at only 19oz - although dont know if this is airframe only, or AUW?If so, then that motor is OTT and you would get away with something of around 150 - 200 watts...Maybe this ?? very inexpensive and 170 watts capableYou may need to drop a prop size though if planning on a 3s Lipo. This motor does have a higher Kv than the others, and may be just a little to high revving. In that case try this at 20 quid ! Of course the trusty wattmeter will tell you all your vitals on the bench. I think this motor is rated at around 19A absolute max, so prop it for about 15A or so to give around 150watts plus on a decent quality 3s battery. Quote Link to comment Share on other sites More sharing options...
Former Member Posted March 1, 2008 Author Share Posted March 1, 2008 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Ashley Hughes Posted March 5, 2008 Share Posted March 5, 2008 I am newish to 3D flying and I am about an attempt at the Maniac free plan in March mag, only problem I have is that I do not understand the motors, AXI2204/54 was suggested but a bit rich for my wallet, have seen several alternatives but not to sure which one, nay suggestions please,regardsash Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted March 5, 2008 Share Posted March 5, 2008 details of model please AUW etc. I keep asking this when these sort of posts appear because it is just not possible to recommend stuff without the information ! Quote Link to comment Share on other sites More sharing options...
