Jean Tardif Posted June 6, 2013 Share Posted June 6, 2013 Hello ,I did somes modification for skis flying with is A-10, fun to fly in powder snow and easy , I leave is retract in place ,I just remove is legs struts and add is skis , easy to do so , and strong stay firm in place, with is two rudders easy to turn on the snow , this warthog is easy to handel and with is motor mount on top is perfect for snow application ., also I made some thrust tubes made with 1/64 plywood for proper diametre for 70 mm fans. I uses two Mega motors 1625-2 with HET 6904 fans, and 6S-5000 LiPo . Cheers Quote Link to comment Share on other sites More sharing options...
Jean Tardif Posted June 6, 2013 Author Share Posted June 6, 2013 Posted by Jean Tardif on 06/06/2013 17:41:44: Hello ,I did somes modification for skis flying with is A-10, fun to fly in powder snow and easy , I leave is retract in place ,I just remove is legs struts and add is skis , easy to do so , and strong stay firm in place, with is two rudders easy to turn on the snow , this warthog is easy to handel and with is motor mount on top is perfect for snow application ., also I made some thrust tubes made with 1/64 plywood for proper diametre for 70 mm fans. I uses two Mega motors 1625-2 with HET 6904 fans, and 6S-5000 LiPo . Cheers **LINK** Quote Link to comment Share on other sites More sharing options...
