J Myers III Posted July 26, 2013 Share Posted July 26, 2013 I have just ordered a 64-mm T-45 kit from Hobbyking which already has an edf unit installed. I have a 4000kv inrunner that is already in a fan that is from a crashed Jetiger that I want to use in the T-45. The thing is, I don't know how to take the motor out of the edf unit... Can anyone help me? Thanks! Quote Link to comment Share on other sites More sharing options...
Allan Bennett Posted July 26, 2013 Share Posted July 26, 2013 Usually you have to first get the impellor off the motor shaft, which may mean removing the spinner and then the main nut that holds it on. Once that's off you'll have access to the smallish bolts that are holding the motor into the housing. Quote Link to comment Share on other sites More sharing options...
J Myers III Posted July 26, 2013 Author Share Posted July 26, 2013 Posted by Allan Bennett on 26/07/2013 20:12:34: Usually you have to first get the impellor off the motor shaft, which may mean removing the spinner and then the main nut that holds it on. Once that's off you'll have access to the smallish bolts that are holding the motor into the housing. Thanks for the reply! How would I remove the spinner? By pulling it off? Quote Link to comment Share on other sites More sharing options...
Allan Bennett Posted July 27, 2013 Share Posted July 27, 2013 On my edfs (not the same brand as yours) the spinners are retained by a screw in their centre, which screws into the end of the prop shaft adapter. If there's nothing obvious on yours, it may just be a snap-fit, or it may itself be threaded so it screws off. I would try twisting it first to see if it's threaded, then a bit of careful prying with a blade to see if it's a snap fit. Quote Link to comment Share on other sites More sharing options...
J Myers III Posted July 27, 2013 Author Share Posted July 27, 2013 Sorry for the late reply but I was able to get the motor out yesterday. Thanks anyway! Quote Link to comment Share on other sites More sharing options...
