legslambert Posted July 27, 2013 Share Posted July 27, 2013 The most annoying noise in the world! I am just starting to set up an E-Flite Hurricane 25e BNF with EFLR7140 sub micros in it. I am checking the electronics are okay and I was going to set up the flaps, but when I power everything up the servos whine like mad. It isn't just one of them. It's whatever is plugged in. They seem to function okay, as does the motor. Does anyone know why my model is screaming? Quote Link to comment Share on other sites More sharing options...
legslambert Posted July 28, 2013 Author Share Posted July 28, 2013 I have discovered that if I put pressure on them with fingertip or slight push against the control horn they will temporarily stop whining. Tweak the sticks to move the servos and off they go again. Could it be something to do with the servos needing to be loaded? Quote Link to comment Share on other sites More sharing options...
Colin Bernard Posted July 28, 2013 Share Posted July 28, 2013 I dont know this model, but looking at the ads for it, it would appear to have digital servos, which are often noisy as they continually hunt around checking they are correctly positioned. Quote Link to comment Share on other sites More sharing options...
WolstonFlyer Posted July 28, 2013 Share Posted July 28, 2013 Agreed , they are high speed digital metal gear servos and will be quite "buzzy" compared to analogue ones. As Colin says they constantly hunt around the centre point and as a result they make more noise. You should not notice when the model is in the air. Quote Link to comment Share on other sites More sharing options...
legslambert Posted July 28, 2013 Author Share Posted July 28, 2013 Thanks Colin and WolstonFlyer, Yes, I knew digital servos were always checking for position, just didn't expect them to be so loud! Or annoying.I haven't used digitals before. Been fiddling with it and the problem is becoming increasingly intermittent. Sometimes they just shut up and are silent. Edited By legslambert on 28/07/2013 22:49:41 Quote Link to comment Share on other sites More sharing options...
Tom Sharp Posted July 29, 2013 Share Posted July 29, 2013 Digital servos feel the weight of the connected surfaces. Hold the model in a vertical position, ie not by the prop, and they will be silent. Quote Link to comment Share on other sites More sharing options...
